1 Answer 0 Score |
equipment stopped working, does not turn on. |
Documents
Background
The Idylis IF50CM23NW is a compact chest freezer produced by Haier America Trading, LLC. This model was introduced in 2014 and has a total volume of 5.0 cubic feet. The freezer is built-in and features a standard door for refrigerator access. Its outer dimensions are 34 inches in height, 29 inches in width, and 22 inches in depth.
The IF50CM23NW utilizes R-410A refrigerant, a non-ozone depleting substance, and its insulation type is also non-ozone-depleting. The freezer operates with an annual energy use of 216.0 kWh/year, which is under the US Federal Standard of 219.0 kWh/year. This model also includes an anti-sweat heater switch. The defrost type is manual, indicating that the user has to manually initiate the defrost process when necessary.
Technical Specifications
- Manufacturer: Haier America Trading, LLC
- Brand Name: Idylis
- Model Number: IF50CM23NW
- Refrigerator Style: Chest Freezer
- Defrost Type: Manual
- Type: Freezer
- Refrigerator Access: Standard Door
- Built-in: Yes
- Compact: Yes
- Anti-Sweat Heater Switch: Yes
- Refrigerant Type: R-410A (Non-Ozone Depleting)
- Insulation Type: Non-Ozone-Depleting
- Freezer Volume (cu ft): 5.0
- Total Volume (cu ft): 5.0
- Height (inches): 34
- Width (inches): 29
- Depth (inches): 22
- Annual Energy Use (kWh/year): 216.0
- US Federal Standard (kWh/year): 219.0
- Date Added: 2014
- Source: California Energy Commission
Haier IF50CM23NW and IF71CM33NW Chest Freezer Service Manual
Idylis IF50CM23NW and IF71CM33NW 5.0 / 7.0 cu. ft. chest freezer use and care guide
Idylis IF50CM23NW / IF71CM33NW 5.0/7.1 Cu. Ft. Chest Freezer Instructions
