Up to 20% off select tools
Documents
nuheara.com shows the item on their web page but don’t mention that it is no longer supported.
It is notorious for a charger that often fails to push the buds down onto the charge electrodes, so they never charge properly. This eventually causes the buds batteries to fail, while the charger still indicates that the buds are okay.
Nuheara technical support on 2012.12.12 told me to FOAD, that they do not replace the batteries, and I’m welcome to spend another $US400 to buy the next upgraded model. The batteries are standard
Although intended for the hard of hearing, who are usually elderly, the app menus are grey text on a grey background with disappearing menus.
When these do work, they are fantastic.
tear down images are attached. These are from an online source.
https://fccid.io/2AKMGMFP0000005/Interna...
and
https://fccid.io/2AKMG00000NU317/Interna...
The buds come apart with a plastic pick pushed gently but firmly along the seam edge.
Once partly open, gently tease out the bluetooth transmitter/receiver and antenna
The red circles need to be de-soldered to remove the battery.
The battery is a CP1654.
i recommend this two for $16.99. It looks like the original Varta brand battery and has a insulation over it.
https://www.amazon.com/CP1654-soundsport...
It is insulated and has wires for easy re-soldering.
This one is called out as being larger than the original battery, so don’t get this:
https://www.amazon.com/Replacement-Compa...
Put a piece of foam on the new battery as a buffer, carefully close it up,
I’ll write a full guide when done.
Author
with
mike banfield
41 Reputation
0 Guides authored
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 50
All Time: 2,349
