Up to 20% off select tools
Guides
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
This mouse combines high-performance features with ergonomic comfort, featuring a right-handed design with padded leatherette side grips. It is specifically designed for right-hand use and may not be suitable for left-handed users. With wireless freedom, long battery life, and a precise sensor, it's ideal for both casual and competitive gamers.
🔧 Technical Specifications
Sensor & Performance
  • Sensor: Pixart PMW3389
  • DPI Range: Up to 16,000 DPI
  • DPI Presets: 800 / 1600 / 3200
  • Speed: 450 IPS
  • Acceleration: 50G
  • Polling Rate: 1000Hz​
Buttons & Switches
  • Total Buttons: 6
  • Switch Type: Omron
  • Switch Durability: 50 million clicks​
Battery & Charging
  • Battery Life:
    • Up to 90 hours (LED off)
    • Up to 50 hours (default LED lighting)
  • Charging Methods:
    • Qi Wireless Charging (charger sold separately)
    • USB-C Wired Charging
Design & Dimensions
  • Ergonomics:
    • Right-handed ergonomic design with padded leatherette side grips
  • Dimensions:
    • Length: 124.8 mm
    • Width: 73.9 mm
    • Height: 43.6 mm
  • Weight:
    • Without cable: 110g
    • With cable: 130g
Lighting & Software
  • RGB Lighting: Per-LED customizable RGB lighting
  • Software: HyperX NGENUITY for customization and battery monitoring​
Connectivity
  • Connection Types:
    • 2.4GHz Wireless
    • Wired via USB-C
  • Included Accessories:
    • USB Charge/Data Cable
    • USB Wireless Receiver
    • Wireless Adapter
    • Quick Start Guide​
Compatibility
  • Platforms: PC, PS5™, PS4™, Xbox Series X|S™, and Xbox One™
Author
with
Nemeš
859 Reputation
2 Guides authored
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 77
All Time: 1,507
