1 Diagram
Models
TA-2530B
Background
The Husky Air Compressor TA-2530B is an air compressor produced by Husky Tools. It is created to serve a variety of purposes in different settings such as homes, farms, and automotive uses, providing power to an array of pneumatic tools and equipment.
The specifications of the Husky Air Compressor TA-2530B include a 2.5HP motor that runs on 120V and 60Hz. It has a tank capacity of 30 gallons and can deliver 5.3 CFM at 40 PSI and 4.7 CFM at 90 PSI. Its maximum pressure output is 135 PSI. The pump type is oil-lubricated and the power cord measures 6 feet in length. The dimensions of the air compressor are 30 x 19 x 40 inches and it weighs 97 lbs. The air compressor features an oil-lubricated pump that provides consistent performance, a 30-gallon air tank for prolonged use of air tools, and a maximum pressure of 135 PSI to power most pneumatic equipment. It has a portable design with wheels and a handle for easy transportation and includes two universal quick-connect outlets for air hose hookups. Overload protection is also provided to prevent motor damage. The TA-2530B air compressor is designed for those who need compressed air for tasks such as operating impact wrenches, ratchets, spray guns, air brushes, nailers, and other pneumatic equipment. The large tank stores more air, reducing the need for frequent restarting.
Technical Specifications
  • Motor: 2.5 HP, 120V, 60 Hz
  • Tank Capacity: 30 gallon
  • CFM @ 40 PSI: 5.3
  • CFM @ 90 PSI: 4.7
  • Max PSI: 135
  • Pump Type: Oil-lubricated
  • Power cord: 6 ft
  • Dimensions: 30 x 19 x 40 in
  • Weight: 97 lbs
Warranty
The Husky Air Compressor TA-2530B comes with a one-year limited warranty. This warranty covers any defects in the material or workmanship of the product. In case of any defect, the company will replace or repair the faulty parts at no extra cost. To claim the warranty, customers should keep their proof of purchase and notify the company about the fault within the warranty period. The product should then be returned to the company for repair or replacement, adhering to the instructions given by the company.
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 21
Past 30 Days: 56
All Time: 870
