No Image
This wiki is missing a device image. Help improve this page by uploading one!
2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Models
H1506FWH
Background
The Husky Air Compressor H1506FWH is a portable electric air compressor. This product has a variety of uses, including powering air tools and inflating tires, making it appropriate for both home and automotive applications.
The air compressor is equipped with a 1.5 HP oil-free electric motor and a 6-gallon tank. It can generate a maximum pressure of 135 PSI and delivers 2.8 CFM at 90 PSI. The product has a 33% duty cycle at 90 PSI and operates from a standard household 120V outlet. The air compressor's dimensions are 20 x 19 x 38 inches, and it weighs 57 lbs.
The air compressor features a compact, portable design with a carrying handle. It uses an oil-free pump, eliminating the need for regular maintenance. The air tank is constructed from cast iron and finished with a powder coat to prevent rust. The product incorporates a regulator, 2 pressure gauges, 2 quick-connect coupler fittings, and a 25-foot coil hose. The motor is safeguarded by an overload switch to avert damage.
The air compressor is suitable for home DIY projects, automotive applications like tire inflation, removing dust, operating roofing nailers, airbrushing, and more. Its 6-gallon tank ensures sufficient air storage for running intermittent use air tools. The oil-free pump design means there is no need for lubrication. The product can inflate a mid-sized car tire from flat to full in around 5 minutes. It has an automatic start/stop functionality that activates the motor when the tank pressure drops and deactivates it when the pressure reaches the maximum PSI. The air compressor also includes rubber feet to minimize vibration.
Technical Specifications
  • Model Number: H1506FWH
  • Product Type: Air Compressor
  • Motor: 1.5 HP oil-free electric motor
  • Tank Capacity: 6 gallons
  • Max Pressure: 135 PSI
  • Air Delivery: 2.8 CFM @ 90 PSI
  • Power Source: Standard household 120V outlet
  • Duty Cycle: 33% at 90 PSI
  • Dimensions: 20 x 19 x 38 inches
  • Weight: 57 lbs
Warranty
The Husky Air Compressor H1506FWH is covered under a 2 year limited warranty. This warranty specifically covers defects in materials and workmanship. However, it's important to note that the warranty does not cover damage that results from misuse, abuse, or normal wear and tear. Also, the warranty is non-transferable and customers are required to provide proof of purchase. In the event of a defect, Husky has the discretion to either repair or replace the defective parts according to the terms of the warranty.
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 29
All Time: 560
