Up to 20% off select tools
No Image
This wiki is missing a device image. Help improve this page by uploading one!
1 Diagram
Ask a Question
There are no questions. Be the first to ask a question!
Models
H1504ST
Background
The Husky Air Compressor H1504ST is an air compressor with a capacity of 4 gallons and is manufactured by Nu Air. It is designed to be portable and is primarily used for homeowner or hobbyist tasks. Its primary function is to provide compressed air for a variety of tasks. These tasks could encompass powering pneumatic tools, inflating tires and sports equipment, and blowing clean pipes or dust.
The Husky Air Compressor H1504ST is powered by a 120 volt electric motor and includes automatic start/stop functionality, meaning it will automatically activate when needed and shut off when not in use. It also features an oil-free pump, allowing for operation without the need for regular maintenance or oil changes. Its design is compact and includes a carry handle, making it convenient to move to different locations as required.
Technical Specifications
  • Manufacturer: Nu Air
  • Brand: Husky
  • Model Number: H1504ST-R
  • Power Source: Corded Electric
  • Voltage: 120 Volts
  • Capacity: 4 Gallons
  • Style: Portable
  • Special Features: Portable
  • Function: The H1504ST is designed for homeowner or hobbyist use. It features a 4 gallon tank and 120 PSI maximum pressure to provide sufficient compressed air for tasks such as powering pneumatic tools, inflating tires and sports equipment, blowing clean pipes or dust, and more.
  • Motor: The unit is powered by a 120 volt electric motor and has automatic start/stop functionality as well as an oil-free pump for maintenance-free operation.
  • Design: The compact, lightweight design with carry handle makes it easy to transport the compressor to wherever compressed air is needed.
  • Safety Features: The unit includes an overload protector to prevent motor burnout and an automatic pressure switch to shut off the motor when full pressure is reached. The tank is ASME certified for safety.
Warranty
The Husky Air Compressor H1504ST comes with a 1-year limited warranty when it is used for residential purposes. This warranty covers any defects that may occur due to materials or workmanship. However, it's important to note that normal wear parts such as air filters are not covered under this warranty. If you need to claim the warranty, it's usually best to contact the manufacturer directly. Make sure to have your proof of purchase and details about the defect or issue.
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 19
All Time: 585
