Up to 20% off select tools
No Image
This wiki is missing a device image. Help improve this page by uploading one!
1 Diagram
Models
H1503TP
Background
The Husky Air Compressor H1503TP is a portable and electrically powered machine designed to generate and store compressed air. Manufactured by The Home Depot, it is intended for utilization in a variety of settings such as home, shop, or garage. The compressor serves to power pneumatic tools and is also capable of inflating vehicle and bicycle tires.
The H1503TP air compressor is characterized by its compact and portable design, featuring a handle on top for easy transport and rubber feet to mitigate vibration. A 2.5-gallon twin stack air tank is incorporated into the machine for the storage of compressed air. The compressor employs an oil-free pump, eliminating the need for oil maintenance. Powering the pump is a 1.5 HP electric motor. Other features include an easily readable front-mounted pressure gauge, a regulator knob for pressure adjustments, and automatic start-stop functionality. The device also supports universal quick connectors for attaching air hoses and pneumatic tools, and includes an integrated cord wrap for organized storage of the power cord.
The Husky H1503TP air compressor can operate small pneumatic tools such as brad nailers, staplers, die grinders, and airbrushes. With its air delivery capabilities, it is adequate for tasks like trim and finish carpentry, hobby-related activities, and automotive applications. The device is also suitable for inflating items such as vehicle and bicycle tires, sports equipment, and pool toys. While it is well-suited for home DIY projects, woodworking shops, and small garages, it is not intended for continuous heavy-duty use in industrial settings.
Technical Specifications
  • Model Number: H1503TP
  • Product: Husky Air Compressor
  • Product Type: Air Compressor
  • Motor: 1.5 HP oil-free electric motor
  • Power supply: 120V, 60Hz electrical outlet
  • Air delivery: 3.0 SCFM at 40 PSI, 2.6 SCFM at 90 PSI
  • Maximum pressure: 135 PSI
  • Tank capacity: 2.5 gallon
  • Pump: Direct drive oil-free pump
  • Dimensions: 17 in x 17 in x 18 in
  • Weight: 29 lbs
Warranty
The Husky Air Compressor H1503TP comes with a limited warranty that lasts for one year. This warranty provides coverage for any defects in materials and workmanship that may be encountered under regular use of the product. However, it is important to note that wear parts such as valves and seals are not included in this warranty. Furthermore, any damages resulting from misuse or accidents are not covered by this warranty.
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 32
All Time: 858
