Up to 20% off select tools
No Image
This wiki is missing a device image. Help improve this page by uploading one!
1 Diagram
Ask a Question
There are no questions. Be the first to ask a question!
Models
F3S33VWD
Background
The Husky Air Compressor F3S33VWD is a portable air compressor made by Husky Tools. This machine is primarily used for inflating tires and operating pneumatic tools, making it suitable for both domestic and automotive applications. It is equipped with a 3.5 HP induction motor and is powered by a 120V household current. The device can deliver 2.6 SCFM at 90 PSI and has a maximum pressure capacity of 135 PSI. Its oil-free pump operates on a direct drive system, and it has a noise level of 78 dBA. The compressor is compact and portable, with dimensions of 17 x 17 x 19 inches and a weight of 32 lbs.
The Husky Air Compressor F3S33VWD is designed for tasks such as inflating tires, air mattresses, and sports equipment, as well as powering air tools like nail guns and staplers. It can also be used for cleaning surfaces by blowing off dust and can be used in spray painting small projects or for abrasive blasting. The compressor can work with pneumatic accessories that require up to 2.6 CFM at 90 PSI air flow and its maximum pressure of 135 PSI allows for the complete inflation of items like vehicle tires.
Technical Specifications
  • Model Number: F3S33VWD
  • Product: Husky Air Compressor F3S33VWD
  • Product Type: Air Compressor
  • Motor: 3.5 HP induction motor
  • Power supply: 120V household current
  • Air delivery: 2.6 SCFM at 90 PSI
  • Tank capacity: 3 gallon
  • Maximum pressure: 135 PSI
  • Pump: Oil-free direct drive
  • Noise level: 78 dBA
  • Dimensions: 17 x 17 x 19 inches
  • Weight: 32 lbs
Warranty
The Husky Air Compressor F3S33VWD comes with a 2-year limited warranty provided by Husky. This warranty covers any defects in the materials and workmanship of the product. However, it's important to note that standard wear parts, such as filters and valves, are not included in the coverage of this warranty. Moreover, any damages that result from misuse, abuse, or improper maintenance of the product are not covered under this warranty. To claim the warranty, the product should be returned to the original place of purchase accompanied by the original receipt.
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 26
All Time: 329
