Up to 20% off select tools
No Image
This wiki is missing a device image. Help improve this page by uploading one!
1 Diagram
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
F2S26VWDVP
Background
The Husky Air Compressor F2S26VWDVP is an electric air compressor produced by Husky Tools. This air compressor features a 2.6-gallon tank capacity and it can deliver a maximum pressure of 150 PSI. The air compressor is well-suited for small domestic improvement projects and automotive applications.
This air compressor is designed to be light and portable, with a weight of 30 lbs. The design is compact and upright, and it includes a steel roll cage to provide protection for its components. The 2.6-gallon tank includes a pressure gauge that is easy to read and a drain valve that is manually operated. The air compressor operates automatically, starting and stopping when the pressure in the tank decreases or reaches its maximum capacity. This functionality allows the air compressor to maintain pressure effectively without overexertion. An overload protector that is thermal in nature prevents the air compressor from overheating.
Technical Specifications
  • Motor: 1.5 hp induction motor
  • Tank capacity: 2.6 gallon
  • Pump: Oil-free direct drive pump
  • Max pressure: 150 PSI
  • Air delivery: 2.0 SCFM @ 90 PSI
  • Power source: Standard 120V household outlet
  • Power cord: 6 ft
  • Weight: 30 lbs
  • Design: Compact upright design with a steel roll cage
  • Pressure gauge: Easy-to-read
  • Drain valve: Manual
  • Automatic start and stop: Yes
  • Thermal overload protector: Yes
Warranty
The Husky Air Compressor F2S26VWDVP comes with a 1-year limited warranty. This warranty covers defects in materials and workmanship. It's important to note that the warranty only covers parts and not labor costs or damages resulting from misuse of the product. In order to claim the warranty, proof of purchase is required, ensuring that the product falls within the warranty period and was purchased from a legitimate source.
Husky 26 Gallon Portable Air Compressor Operator's Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 21
All Time: 319
