2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
F2S20VWD
Background
The Husky Air Compressor F2S20VWD is a portable air compressor intended for various applications. This product is characterized by its portability, made explicit by its compact form and the inclusion of a carrying handle. It has a 2-gallon steel air tank and a pump made of aluminum that does not require oil, removing the need for regular maintenance. The air compressor features a quick connect coupler intended for attaching accessories that utilize air, and a regulator gauge for monitoring tank and outlet pressure. Manual thermal overload protection and rubber feet that prevent movement during operation are also part of its design.
The air compressor has a variety of uses, including the inflation of tires, sports balls, and pool toys. It can also power air tools such as nailers, staplers, and blow guns. Cleaning equipment, furniture, and electronics with compressed air is possible using this product, as is operating small air brushes for projects and crafts. It is suitable for use in home workshops, garages, and small automotive shops. Its oil-free pump, which requires no maintenance, offers versatility for inflating and air tool tasks.
Technical Specifications
- Model Number: F2S20VWD
- Product Type: Air Compressor
- Power: 2 HP
- Voltage: 120 V
- Amperage: 15 A
- Tank Capacity: 2 Gallons
- CFM @ 40 PSI: 0.8
- CFM @ 90 PSI: 0.5
- Max PSI: 120
- Pump Type: Oil-Free
- Pump Material: Aluminum
- Power Cord Length: 6 ft
- Dimensions: 17 x 11 x 19 in
- Weight: 32 lbs
Warranty
The Husky Air Compressor F2S20VWD is backed by a 1-year limited warranty. This warranty covers any defects that arise from the materials or workmanship of the product. However, it doesn't cover normal wear items such as filters and accessories. In order to claim the warranty, users are required to provide proof of purchase along with the date of purchase.
Husky 20/26-Gallon Portable Air Compressor Use and Care Guide
