Up to 20% off select tools
No Image
This wiki is missing a device image. Help improve this page by uploading one!
1 Diagram
Ask a Question
There are no questions. Be the first to ask a question!
Models
CT10H
Background
The Husky Air Compressor CT10H is a machine designed to pressurize air for various uses. It is primarily used in homes, workshops, and for automotive purposes, where it powers pneumatic tools and inflates tires. The device is equipped with a 10 HP electric motor, has a tank with a capacity of 10 gallons, and can deliver air at 5.7 SCFM at 90 PSI. The maximum pressure it can achieve is 135 PSI. The dimensions of the compressor are 30 x 19 x 40 inches, and it has a weight of 157 lbs.
This air compressor is equipped with several features including an oil lubricated pump that allows it to operate coolly and quietly, thermal overload protection to guard the motor from damage, and a quick connect air outlet to simplify tool connections. It also has large tires and a front handle to enhance portability. A manual drain valve is included for the removal of moisture from the tank. The device also has two regulated air outlets, enabling users to operate multiple tools simultaneously.
Technical Specifications
  • Power source: 10 HP electric motor
  • Tank capacity: 10 gallon
  • Air delivery: 5.7 SCFM @ 90 PSI
  • Maximum pressure: 135 PSI
  • Power cord length: 25 ft
  • Dimensions: 30 x 19 x 40 inches
  • Weight: 157 lbs
Warranty
The Husky Air Compressor CT10H comes with a 12-month limited warranty. This warranty covers defects in materials and workmanship, ensuring that the product you have purchased is of high quality and free from any manufacturing faults. It is important to note that this warranty only applies to the original purchaser of the product, and requires proof of purchase when making a claim. Any damages that result from misuse or negligence are not covered under this warranty.
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 24
All Time: 399
