Up to 20% off select tools
No Image
This wiki is missing a device image. Help improve this page by uploading one!
2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Models
C802H
Background
The Husky Air Compressor C802H is an electric air compressor. The device is portable, designed to be used by individuals for home-based projects or hobbies. It has the capacity to operate various pneumatic tools such as airbrushes, nail guns, and impact wrenches.
This air compressor is equipped with a 2 HP motor. It runs on a power supply of 120V, 60Hz and offers an air delivery of 5.3 SCFM at 90 PSI. The maximum pressure that can be achieved is 135 PSI. It contains a 2-gallon tank and an oil-lubricated pump. The compressor features 2 quick connect outlets for connecting air hoses and tools. Its dimensions are 20 x 17 x 18 inches and it weighs 42 lbs. The device has rubber feet and a handle for portability. The air compressor also incorporates thermal overload protection to prevent motor damage. The product is designed for a variety of uses including inflation, nailing, stapling, and airbrushing. Its 2-gallon tank capacity reduces cycling, which can lead to improved motor lifespan.
Technical Specifications
  • Motor: 2 HP
  • Power supply: 120V, 60Hz
  • Air delivery: 5.3 SCFM at 90 PSI
  • Maximum pressure: 135 PSI
  • Tank capacity: 2 gallons
  • Pump type: Oil-lubricated
  • Outlets: 2 quick connect outlets
  • Dimensions: 20 x 17 x 18 inches
  • Weight: 42 lbs
Warranty
The Husky Air Compressor C802H is provided with a 1-year limited warranty. This warranty is specifically designed to cover any defects in the materials or workmanship of the product. To claim the warranty, the owner must provide proof of purchase and be located within the United States. However, it's important to note that this warranty does not extend to any damage that may have occurred due to misuse or accidents.
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 21
All Time: 294
