Up to 20% off select tools
No Image
This wiki is missing a device image. Help improve this page by uploading one!
2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Models
C801H
Background
The Husky C801H is an air compressor that is primarily utilized for individual and light commercial purposes, with the capability of delivering up to 150 PSI of air pressure. This product is manufactured by Husky Tools.
The specifications of the Husky C801H include a 1.5 HP oil-lubricated motor, an 8-gallon tank capacity, an air delivery rate of 5.7 SCFM at 90 PSI, a maximum pressure of 150 PSI, and a power source that is corded electric, 120V 15A. The dimensions of the compressor are 28 x 28 x 46 inches and it weighs 138 lbs. Its design includes two universal quick connect air outlets that permit the connection of pneumatic tools, an oil sight glass, an oil drain valve, and an air pressure regulator. The Husky C801H is suitable for home DIY projects, automobile tire inflation, small shop tools, and other light-duty applications. It can power a variety of tools including nailers, staplers, spray guns, sanders, and impact wrenches. The high maximum pressure ensures optimal tool performance.
Technical Specifications
  • Motor: 1.5 HP oil-lubricated
  • Tank capacity: 8 gallon
  • Air delivery: 5.7 SCFM at 90 PSI
  • Maximum pressure: 150 PSI
  • Power source: Corded electric, 120V 15A
  • Dimensions: 28 x 28 x 46 in
  • Weight: 138 lbs
Warranty
The Husky Air Compressor C801H comes with a limited warranty that lasts for a duration of 2 years. This warranty covers any defects that may arise in materials or workmanship under normal use conditions. However, it is important to note that the warranty does not extend to cover damage resulting from misuse, abuse, or incorrect maintenance. In order to claim the warranty, you need to provide proof of purchase, and it is only valid for the original owner of the product.
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 19
All Time: 429
