Up to 20% off select tools
No Image
This wiki is missing a device image. Help improve this page by uploading one!
2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Models
C201H
Background
The Husky Air Compressor C201H is a portable air compressor designed for various applications including home DIY, automotive, and small shop uses. It operates on electricity and is equipped with a 1.5 HP motor. The compressor has a 2.5 gallon tank capacity and can achieve a maximum pressure of 150 PSI. It delivers an air flow of 0.7 CFM at 90 PSI. The dimensions of the unit measure 17 x 17 x 19 inches and it weighs 32 lbs.
The Husky C201H is compact and portable, suitable for light-duty tasks. The 2.5 gallon tank is made of rolled steel and can store pressurized air up to 150 PSI. The pump, which requires no oil, provides 0.7 CFM of airflow at 90 PSI, making it suitable for intermittent use tools such as nail guns, staplers, inflators, and airbrushes. The compressor has a 1.5 HP electric motor with thermal overload protection and the unit is designed for durability, with a cast iron cylinder and V-belt drive system. It also includes features such as rubber feet to reduce vibration. The compressor comes with a 6 ft power cord, a 16 ft coiled air hose, inflator needle, and a blow gun. The controls on the unit are manual and straightforward.
Technical Specifications
  • Power source: Electric
  • Motor: 1.5 HP
  • Tank capacity: 2.5 gallon
  • Max pressure: 150 PSI
  • Air delivery: 0.7 CFM @ 90 PSI
  • Power cord length: 6 ft
  • Dimensions: 17 x 17 x 19 inches
  • Weight: 32 lbs
Warranty
The Husky Air Compressor C201H is provided with a 1 year warranty. This warranty coverage includes defects in materials and workmanship under normal usage conditions. It's important to note that the warranty does not extend to any damage resulting from misuse or accidents. In order to claim the warranty, it is typically required to provide proof of purchase and contact the manufacturer directly, though specific instructions for claiming the warranty may vary and should be detailed in your product's user manual or warranty card.
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 32
All Time: 641
