Up to 20% off select tools
No Image
This wiki is missing a device image. Help improve this page by uploading one!
1 Diagram
Ask a Question
There are no questions. Be the first to ask a question!
Models
BS1004W
Background
The Husky Air Compressor BS1004W is a portable air compressor equipped with a 1 horsepower motor and a 4-gallon tank. It operates on an oil-free direct drive pump, eliminating the need for oil maintenance. The compressor functions at a maximum pressure of 150 PSI and delivers 2.6 standard cubic feet per minute (SCFM) at 90 PSI. This makes it suitable for tasks that require the use of compressed air, including home DIY, automotive, and workshop projects.
The Husky BS1004W is relatively compact and lightweight, at 39 pounds. It includes an air hose, inflation needles and nozzles, and an air blow gun. The compressor's motor and pump feature thermal overload protection. Its maximum pressure capability of 150 PSI enables it to be used for nailing, stapling, air brushing, and drilling applications. This air compressor is particularly useful for tasks that require intermittent use of air tools and spray painting.
Technical Specifications
  • Model Number: BS1004W
  • Product: Husky Air Compressor BS1004W
  • Product Type: Air Compressor
  • Power: 1 HP
  • Voltage: 110 Volts
  • Tank Capacity: 4 Gallons
  • Dimensions: 23.8 x 9.7 x 19.7 inches (Length x Width x Height)
  • Weight: 39 pounds
  • Maximum Pressure: 150 PSI
  • Air Delivery: 2.6 SCFM at 90 PSI
  • Pump Type: Oil-free direct drive
  • Motor Type: Single stage
  • Noise Level: Less than 78 dBA
  • Included Components: Air hose, inflation needles and nozzles, air blow gun
Warranty
The Husky Air Compressor BS1004W comes with a 2-year limited warranty. This warranty typically covers any defects that are due to faulty materials or workmanship. However, the specifics of what exactly is covered can vary depending on the terms and conditions stated by the manufacturer. To claim the warranty, the user might need to provide proof of purchase and contact the manufacturer's customer service directly. It's always advisable to keep the original receipt and warranty card safe to ensure a smooth warranty claim process.
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 33
All Time: 587
