Up to 20% off select tools
No Image
This wiki is missing a device image. Help improve this page by uploading one!
1 Diagram
Ask a Question
There are no questions. Be the first to ask a question!
Models
671-049
Background
The Husky Air Compressor 671-049 is a portable air compressor. Featuring a gasoline engine, specifically a 7 HP Honda GX200, it has a tank capacity of 6 gallons. It has a pump flow rate of 5.3 CFM at 40 PSI and 4.7 CFM at 90 PSI, with a maximum pressure of 135 PSI. The noise level is measured at 78 dBA. The dimensions of this model are 24 x 17 x 25 inches and it weighs 82 lbs.
This air compressor is designed for portability, with a compact design that includes a roll cage and two flat-free tires for easier movement around different locations. It includes a low oil shutdown feature to prevent damage if the oil level drops too low. The pump is also oil lubricated to ensure cooler operation. The Husky 671-049 is equipped for inflation and air tool operation. Regular maintenance, such as checking oil levels, changing oil, cleaning air filters and checking for loose parts, is recommended for optimal performance.
Technical Specifications
  • Model Number: 671-049
  • Product Type: Air Compressor
  • Power Source: Gasoline engine
  • Engine: 7 HP Honda GX200
  • Tank Capacity: 6 gallon
  • Pump Flow Rate (@ 40 PSI): 5.3 CFM
  • Pump Flow Rate (@ 90 PSI): 4.7 CFM
  • Maximum Pressure: 135 PSI
  • Noise Level: 78 dBA
  • Dimensions: 24 x 17 x 25 in
  • Weight: 82 lbs
Warranty
The Husky Air Compressor 671-049 comes with a 2-year limited warranty. This warranty covers any defects in materials and workmanship from the date of purchase. It is important to note that the warranty for the engine is handled separately by Honda. To claim the warranty, follow the guidelines provided in the product's user manual or contact the manufacturer's customer service. Please ensure that you have your purchase receipt or proof of purchase when making a warranty claim.
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 33
All Time: 510
