No Image
This wiki is missing a device image. Help improve this page by uploading one!
1 Diagram
Ask a Question
There are no questions. Be the first to ask a question!
Models
585-819
Background
The Husky Air Compressor 585-819 is a portable air compressor designed for various applications such as home DIY, automotive, and small shop use. This air compressor is equipped with a 2 horsepower oil-free pump, delivering an air delivery rate of 5.3 CFM at 90 PSI, with a maximum pressure of 135 PSI. The unit's tank has a capacity of 6 gallons and is constructed from durable steel with a rust-resistant finish.
This air compressor is portable, featuring two wheels and a handle for easy movement. The oil-free pump design negates the need for maintenance and includes overload protection to avoid overheating. The unit features easy-to-reach analog gauges for monitoring tank and regulator pressure and is fitted with two universal quick connect couplers for attaching air accessories. The unit is controlled via an on/off switch.
Technical Specifications
  • Model Number: 585-819
  • Product Type: Air Compressor
  • Power: 2 horsepower
  • Tank size: 6 gallon
  • Air delivery: 5.3 CFM @ 90 PSI
  • Maximum pressure: 135 PSI
  • Power source: 120V / 15A
  • Pump type: Oil-free
  • Weight: 50 lbs
  • Portability: Portable design with two wheels and handle
  • Overload Protection: Yes
  • Gauges: Analog gauges for tank and regulator pressure monitoring
  • Couplers: Two universal quick connect couplers
  • Control: On/off switch
Warranty
The Husky Air Compressor 585-819 comes with a 2-year limited warranty. This warranty covers any defects in the materials and workmanship for a period of 2 years from the date of purchase. However, it's important to note that normal wear items, such as air filters, are not included in the warranty coverage. To claim the warranty, customers must retain their original receipt as proof of purchase.
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 23
All Time: 385
