Up to 20% off select tools
No Image
This wiki is missing a device image. Help improve this page by uploading one!
3 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Models
136424
Background
The Husky Air Compressor 136424 is a type of air compressor used for powering various air tools, such as nail guns, spray guns, and air ratchets. It is primarily intended for use in home workshops and garages. The device operates on a 120V, 60Hz electrical outlet, and possesses a motor with 2 horsepower. The air compressor comes with a tank capacity of 6 gallons, and it can achieve a maximum pressure of 150 PSI. Other features of the compressor include a regulator and gauges for air pressure control, a quick-connect coupler for attaching air tools, rubber feet to minimize vibration, and a shroud for pump and motor protection.
The Husky Air Compressor 136424 also has a dual pressure regulator, which allows for the operation of two tools simultaneously. The compressor is primarily used with common workshop tools such as brad nailers, staplers, air ratchets, spray guns, blow guns, air brushes, and more. However, it is not designed for heavy duty, high volume air tools like jackhammers or sandblasters, nor is it suitable for commercial or industrial workshop use. It is mainly intended for home DIYers who need occasional air power. Regular maintenance of the Husky Air Compressor 136424 includes checking and changing the oil to prevent pump damage, draining moisture from the tank periodically to prevent corrosion, and replacing the air filter as needed to maintain air flow.
Technical Specifications
  • Power supply: 120V, 60Hz electrical outlet
  • Motor: 2 horsepower
  • Tank capacity: 6 gallon
  • Maximum pressure: 150 PSI
  • Air delivery: 5.3 SCFM at 90 PSI
  • Noise level: 78 decibels
  • Dimensions: 24 x 19 x 25 inches
  • Weight: 75 lbs
Warranty
The Husky Air Compressor 136424 comes with a 2-year limited warranty. This warranty covers any defects in the materials and workmanship of the product. Please note that the warranty does not extend to any damage caused by misuse or accidents. To claim the warranty, you will need to provide proof of purchase.
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 37
All Time: 711
