Up to 20% off select tools
Guides
Ask a Question
There are no questions. Be the first to ask a question!
Background Information
Initially revealed in May 2023 and officially announced in July 2023, the Humane AI Pin is an AI assistant meant to replace traditional smartphones.
The AI Pin's notable lack of an LCD sets it apart from smartphones. Instead, it can be operated by voice commands, touch gestures for quick actions, or the Laser Beam Scanning Projection System.
The Humane AI Pin is available in three different finishes.
  • Eclipse: Super Matte Black Anodized finish w/ Black Touchpad for $700
  • Equinox: Polished Silver Finish w/ Black Touchpad for $800
  • Lunar: Polished Silver Finish w/ White Touchpad $800
The AI pin was heavily criticized for its limited battery life and poor thermal control, as well as the questionable usefulness of many of the AI features. In terms of user factor, the device has been compared to smartphones in terms of its usage in daily life.
On February 18, 2025, HP announced that they had reached an agreement with Humane to acquire their AI capabilities to integrate into HP's products. This includes Humane's operating system CosmOS, technical talent, and all intellectual property relating to the AI pin, with more than 300 patents and patent applications. Customer availability, AI features, and data access was cut off on Febuary 28, 2025 at 12 pm PST.
News
Technical Specifications
Summary
  • Display: Laser Ink Display
  • Processor: Octa-core Qualcomm Snapdragon
  • Camera: 12 MP Wide Camera
  • Charging: Wireless Power Charging Method
  • Operating System: CosmOS
  • Cellular: 4G LTE
  • Storage: 32 GB eMMC
  • Clasps:
    • Latch
    • Battery Booster
    • Clip
Colors/Housing Finishes
  • Finishes/Touchpad Colors
Dimensions
  • AI Pin Dimensions:
    • Length: 1.87" (47.5 mm)
    • Width: 1.75" (44.5 mm)
    • Depth: 0.59" (14.98 mm) @ thickest point, 0.32" (8.25 mm) @ thinnest point
    • Weight: 34.2 g
  • Battery Booster Dimensions:
    • Length: 1.86" (47.16 mm)
    • Width: 1.78" (45.2 mm)
    • Depth: 0.32" (8.25 mm)
    • Weight: 20.5 g
Display
  • Type: Laser Ink Display
  • Technology: Laser Beam Scanning Projection System
  • Resolution: 720p Resolution
  • Operating Distance: 7.87" (20 cm) - 15.75" (40 cm)
  • Field-of-View: 18.2° wide, 13.3° tall, 22.4° diagonal (7 cm x 9.6 cm at 30 cm distance)
Laser
  • Diode: Custom-Color Single-Diode Laser
  • Safety Classification: Class 2 per IEC60825-2014
  • Peak Wavelength: 498 nm
  • Projection Divergence half-angles: 18.2° x 13.3°
  • Projection divergence full FOV: 18.2° x 13.3°
  • Projection divergence half angles: 9.1° x 6.7°
  • Variable pulse duration: 10 ns - 20 µs
  • Peak Emissions: 25 mW
Audio
  • Output: Built-in Speaker
  • Input: Dual Microphone Array
  • Audio Codec: AAC
  • Audio Calling: Voice over LTE (VoLTE), 3G
What's in the Box
  • 2 x Battery Boosters
  • 1 x USB-C Adapter and Cable
  • 1 x Charge Pad
  • 1 x Charge Case
Additional Information
Author
with
Jacob Mehnert
50,876 Reputation
52 Guides authored
iFanatics Member of iFanatics
Community
71 Members
1,152 Guides authored
Past 24 Hours: 2
Past 7 Days: 54
Past 30 Days: 191
All Time: 4,257
