Up to 20% off select tools
Guides
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background and Identification
The Huawei Honor 7 Android smartphone was released by Huawei as part of their Honor sub-brand. The Honor 7 was released internationally with grey and silver bodies and 16 GB or 64 GB of internal storage. In China, one variant of the Honor 7 includes a gold-colored body with dual SIM capabilities and 64 GB of internal storage. The Indian variant includes only single-SIM capabilities. Its predecessor is the Honor 6, which was released in 2014.
The Honor 7 features an aluminum backing and frame with a 5.2-inch touchscreen display. It includes a 20-megapixel main camera and an 8-megapixel front camera. The Honor 7 also includes a fingerprint sensor and a ‘Smart’ button that can be assigned specific tasks to personalize the device. The international version features dual-SIM functionality, but only one SIM can be used if operated with an additional Micro-SD card for expanded storage. The Honor 7 includes accelerometer, gyro, proximity, and compass sensors, as well as fast-charging capabilities.
Reviews have found that the Honor 7’s rear-mounted fingerprint scanner does not always work flawlessly and the phone has sub-par battery life.
While the Honor 7 includes only 3 GB of RAM, it’s successor—called the Honor 8—includes 4 GB of RAM as well as a USB-C port.
Technical Specifications
Models: PLK-L01, PLK-AL10, PLK-UL00, PLK-TL01H
Release date: July 2015
Body:
  • Dimensions and Weight: 143.2 x 71.9 x 8.5 mm (5.64 x 2.83 x 0.33 in), 157 g (5.54 oz)
  • Build: Glass front (Gorilla Glass 3), aluminum back, aluminum frame
  • SIM: Single SIM (Nano-SIM) or Hybrid Dual SIM (Nano-SIM, dual stand-by)
Display:
  • Type: IPS-NEO LCD capacitive touchscreen, 16M colors
  • Size: 5.2 inches, 74.5 cm2 (~72.4% screen-to-body ratio)
  • Resolution: 1080 x 1920 pixels, 16:9 ratio (~424 ppi density)
  • Protection: Corning Gorilla Glass 3
Platform:
  • OS: Android 5.0 (Lollipop), upgradable to 6.0 (Marshmallow), EMUI 3.1
  • Chipset: Kirin 935 (28 nm)
  • CPU: Octa-core (4x2.2 GHz Cortex-A53 & 4x1.5 GHz Cortex-A53)
  • GPU: Mali-T628 MP4
Memory:
  • Card slot: microSDXC (uses shared SIM slot)
  • Internal:16GB 3GB RAM, 32GB 3GB RAM, 64GB 3GB RAM
Main Camera:
  • Single: 8 MP, f/2.4, 26mm (wide)
  • Features: LED flash
  • Video:1080p@30fps, HDR
Selfie Camera:
  • Video: 1080p@30fps
Sound:
  • Loudspeaker: yes
  • 3.5 mm jack: yes
Communications:
  • WLAN: Wi-Fi 802.11 a/b/g/n/ac, dual-band, Wi-Fi Direct, hotspot
  • Bluetooth: 4.1, A2DP, EDR, LE
  • GPS: Yes, with A-GPS, GLONASS/BDS
  • NFC: Yes
  • Radio: Stereo FM Radio
  • USB: MicroUSB 2.0
Features:
  • Sensors: Fingerprint (rear-mounted), accelerometer, gyro, proximity, compass
Battery:
  • Non-removable Li-Po 3100 mAh battery
  • Charging: Fast charging 18W
  • Stand-by: Up to 350 h (3G)
  • Music play: Up to 8 h 20 min (3G)
Miscellaneous:
  • Colors: Gray, Silver, Gold
  • SAR EU: 1.13 W/kg (head)     0.52 W/kg (body)
Additional Information
Author
with
Dominik Schnabelrauch
268,200 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
Past 24 Hours: 3
Past 7 Days: 29
Past 30 Days: 106
All Time: 12,754
