Up to 20% off select tools
Guides
Ask a Question
There are no questions. Be the first to ask a question!
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
Honda CSC29 ID: 9764219-329 104210-3293
Honda uses DENSO manufactured alternators as original parts in its vehicles, in which the alternators' lightweight, highly efficient, and durable design makes them well-suited for rough conditions. DENSO alternators are subjected to rigorous tests in which the stators and rectifiers are tested at 300 volts, and the rotors are tested at 600 volts. Additionally, the rotor slip rings are buffed to an 8-micron surface finish, with run-out limited to 20 microns, which minimizes brush wear and abrasions. The Bearings are set to OE standards and loaded with premium OE-standard lubricants.
Available in versions ranging from 40 to 160 amperes and beyond for a plethora of specific vehicle applications, all alternators meet DENSO's rigorous First Time Fit® standards. "DENSO First Time Fit alternators meet or exceed all manufacturer standards, mount properly with a minimum of installation issues, and provide years of reliable service."
Identification
The Honda CSC29 measures 9.3 × 7.4 × 7.3 inches and weighs 13.4 lb. It features an aluminum housing with a black plastic top. You can identify the alternator by the Honda logo, model number, and other information printed on a label on the side of the part.
Additional Information
Clear Diagram of the Honda CSC29 Alternator
Description of Alternator Parts
Alternator replacement cost, best practices, common symptoms, and common misdiagnoses
Honda CSC29 on Amazon
Author
with
Raymond Akagi
241 Reputation
1 Guide authored
Cal Poly, Team 25-1, Maness Spring 2016 Member of Cal Poly, Team 25-1, Maness Spring 2016
CPSU-MANESS-S16S25G1
4 Members
60 Guides authored
Past 24 Hours: 6
Past 7 Days: 34
Past 30 Days: 111
All Time: 10,117
