Guides
23 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Models
EG6500CL AT
Background and Identification
The Honda Generator model EG6500CL AT is a 6500 Watt generator that is designed for use with professional tools like circular saws, drills, and air compressors. It provides power for large appliances and big job sites and includes a voltage selector that allows the user to switch between 120 and 240 Volts.
The Honda Generator model EG6500CL AT includes a Honda Commercial GX390 engine. The GX390 is a 389 cubic centimeter air-cooled four-stroke overhead valve (OHV) engine. It produces a net power output of 11.7 horsepower at 3,600 revolutions per minute. The engine includes a butterfly float type carburetor and a digital CDI with a variable timing ignition system. It can contain up to 1.16 quarts (1.1 Liters) of oil and up to 6.4 quarts (6.1 Liters) of fuel. Honda recommends using unleaded 86 octane or higher fuel with this engine.
The Honda Generator model EG6500CL AT features Honda’s Digital Auto Voltage Regulation (DAVR) and can run up to 10 hours at 50% load. The generator includes an electric ignition and a USDA-qualified spark arrestor/muffler.
The generator includes a welded steel frame with a red plastic top and the model number “EG 6500 CL” in grey font on the side of the generator. It includes two wheels and two grab-bars for maneuverability. The engine is located between the generator’s wheels and includes the name “Honda GX 390” on the front of the red engine cover.
Technical Specifications
Details:
  • AC Output: 120/240V 6500W max. (54.2/27.1A) / 5500W rated (45.8/22.9A)
  • Receptacles: 20A 125V Duplex, 30A 125V Locking Plug, 30A 125/250V Locking Plug
  • Starting System: Recoil
  • Fuel Tank Capacity: 6.3 gal
  • Run Time per Tankful: 7.1 hrs. @ rated load, 10.0hrs. @ 1/2 load
  • Noise Level: 74 dB @ rated load
Dimensions:
  • Assembled Depth (in.): 26.8 in
  • Assembled Height (in.): 22.7 in
  • Assembled Width (in.): 22.8 in
Additional Information
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 2
Past 7 Days: 51
Past 30 Days: 197
All Time: 9,956
