1 Diagram
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
DH 40MRY
Background
The Hitachi Rotary Hammer DH 40MRY (2015) is a rotary drill used to drill into tough surfaces such as brick, stone, or concrete, and is ideal for jobs such as construction, renovation, and DIY projects. The tool features a counterweight, which reduces the vibration that the drill creates by over 50%, which allows for a longer tool life. The tool has 2 modes, hammer drilling and hammer only, which allows for flexibility depending on use. The tool also has an adjustable side arm, for easier maneuverability.
The Hitachi Rotary Hammer DH 40MRY (2015) was released in 2015 and is a highly popular tool used for drilling. The device is primarily available in North America, but it can be shipped to almost any place worldwide. The target demographic would be people working in construction or home projects. The selling price of the tool ranges from $275 to $650$, depending on its condition.
The tool is highly praised for its high performance and efficiency, as it can melt through concrete faster than the competition, and has received many positive reviews, and there are no common complaints regarding the tool.
The Hitachi Rotary Hammer DH 40MRY (2015) is a rotary hammer drill under the Hitachi's drill family. It has a 9.2 amp motor and 950 watts of input power and requires 103.26V. It has a 1-9/16 inch chunk size and an ergonomic grip for ease of handling. The tool is compact, yet powerful, allowing for high performance. The DH 40MRY (2015) contains features that allow for adjustments and safety, such as an adjustable side handle, a needle-pin slip clutch to protect the gears and the user, a variable lock mechanism for 12-angle positions, and a quick release system for simple bit changes, idle strike restrictor to prevent no-load activation and additional wear on the tool, and a dust-resistant structure to guard internal components from harmful debris as well as grease leakage.
Identification
The Hitachi Rotary Hammer DH 40MRY (2015) is a black, white, and green tool, with the black part at the end closer to the drill bit, the green near the handle, and the white in the middle near the logo, "HITACHI". The model number is printed right below the logo. The handle grip is made of soft elastomer and it has a side handle that can be adjusted. The tool is 17.87 x 13.50 x 4.12 inches in dimension and is 16.5 pounds in weight.
Technical Specifications
- Product depth: 17.87 inches
- Product height: 13.50 inches
- Product width: 4.12 inches
- Product weight: 16.5 pounds
- Motor: 9.2 Amp
- Number of angle positions: 12
- Variable speed: Yes
- Battery included: No
- Brand: Hitachi
- Type: Rotary Hammer Drill
- Power source: Plug
- Voltage: 103.26V
- Watts: 950W
- Model: DH 40MRY
- Color: Black, White, and Green
