3 Diagrams
Models
C12LSH
Background
The Hitachi C12LSH is a miter saw known for its 15 amp 12-inch dual bevel sliding compound design. This tool is primarily utilized for making precise cross cuts and miters in various materials, such as wood, plywood, crown molding, decorative panels, fiberboard, and aluminum.
The saw is equipped with a variety of features. These include a 15 amp motor that can reach a no-load speed of 3,800 RPM, a 12" TCT saw blade, miter and bevel scales with a wide range and micro adjust knobs for precise adjustments, and a laser marker system for accurate alignment. It also has a digital LCD display for viewing miter and bevel angles, a compact slide system that doesn't require rear clearance, a pivoting fence for vertical crown molding cuts, and a fixed splinter guard for clean cuts. Other notable features include a vertical handle with vibration reduction, a dust collection bag, and easily accessible carbon brushes.
Technical Specifications
  • Model Number: C12LSH
  • Product Type: Miter Saw
  • Power: 15 amp motor, 1,850 watt
  • No load speed: 3,800 RPM
  • Blade diameter: 12"
  • Blade material: Stainless steel
  • Blade tooth count: 60
  • Miter angle range: 0° to 46° left, 0° to 57° right
  • Bevel angle range: 0° to 45° left and right
  • Max cutting capacity: 5-1/4" height, 12" cross-cut width
  • Laser marker system: Yes
  • Digital LCD display: Yes
  • Dimensions: 30" x 23.4" x 27.9"
  • Weight: 66.1 lbs
Warranty
The Hitachi C12LSH comes with a warranty period of 5 years provided by the manufacturer. This warranty coverage is designed to protect against any manufacturing defects that may arise during this time. Additionally, the product also comes with a 30-day money-back guarantee. To claim the warranty, users would typically need to reach out to the manufacturer with proof of purchase. It is important to remember that the warranty may not cover damage caused by misuse or any modifications made to the product.
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 15
Past 30 Days: 42
All Time: 590
