No Image
This wiki is missing a device image. Help improve this page by uploading one!
3 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Models
CG 22EAS
Background
The Hitachi CG 22EAS is a brush cutter powered by a 22cc 2-stroke gasoline engine. This model was introduced in 2015 by Hitachi Koki Co., Ltd. and is typically used in commercial landscaping. The brush cutter is equipped with a centrifugal clutch and an angled straight shaft, allowing the cutting head to access areas under low foliage. The cutting head can be equipped with either a nylon cord or a steel blade for the purpose of cutting through dense brush.
The engine of the Hitachi CG 22EAS is air-cooled and utilizes a recoil starter. It has a fuel tank with a capacity of 0.6 liters and burns fuel at a rate of 0.37 liters per hour when operating under full load. The brush cutter weighs 6.1 kg without the cutting attachment and includes an anti-vibration system to decrease operator fatigue during prolonged use. The cutter comes with a nylon cord head for trimming grass and light vegetation, and optional attachments include a 3-tooth grass blade and an 8-tooth brush cutter blade. These blades can cut through small trees and thick brush up to 20mm in diameter. The shaft is compatible with attachments with an M10 thread. The brush cutter includes a rear D-grip handle that can be adjusted without tools and comes with a shoulder strap.
Technical Specifications
  • Model Number: CG 22EAS
  • Product Type: Brush Cutter
  • Engine Type: 22cc 2-stroke gasoline
  • Power Output: 0.75 kW
  • Fuel Tank Capacity: 0.6 liters
  • Fuel Consumption: 0.37 liters/hour
  • Dry Weight: 6.1 kg
  • Cutting Attachments: Nylon line, grass blade, brush cutter blade
  • Maximum Cutting Diameter: 20mm
  • Shaft Type: Straight, angled
  • Handle Type: Rear D-grip, adjustable
  • Anti-Vibration Feature: Yes
Warranty
The Hitachi Brush Cutter CG 22EAS comes with a 2-year consumer warranty. This warranty covers any defects in the materials and workmanship of the product, but it is only applicable to non-commercial use. In order to claim the warranty, it's typically necessary to provide proof of purchase and report the issue within the warranty period. The specific process for claiming the warranty may vary and could entail contacting Hitachi's customer service or returning the product to the place of purchase.
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 38
All Time: 655
