Up to 20% off select tools
1 Diagram
Documents
Models
G 12SS
Background
The Hitachi G12SS Angle Grinder is a corded electric power tool. This compact, lightweight angle grinder is 10 inches in length and weighs 3 pounds, making it suitable for handling and control. It operates at a voltage of 120 Volts, with a wattage of 580 Watts and a horsepower of 0.58 HP. The grinder's no-load speed reaches 11,000 RPM, and it uses a disk with a diameter of 4.5 inches. It includes a paddle switch for operation and is constructed of glass-reinforced polymide resin, with a gear housing made of die-cast aluminum.
The Hitachi G12SS Angle Grinder, with its compact and lightweight design, aids in grinding metals, removing paint and rust, performing masonry work, and sanding applications. Its ergonomic design, featuring a narrow grip circumference and a forward canted side handle, contributes to reducing user fatigue during prolonged use. The low-profile head of the grinder enables access to tight spaces. For maintenance, the brushes are externally accessible. The package includes a paddle switch, a depressed center wheel, a wrench, and a side handle.
Technical Specifications
  • Manufacturer: Hitachi
  • Model Number: G12SS
  • Weight: 3 pounds
  • Length: 10 inches
  • Power Source: Corded Electric
  • Voltage: 120 Volts
  • Wattage: 580 Watts
  • Horsepower: 0.58 HP
  • No Load Speed: 11,000 RPM
  • Disc Diameter: 4.5 inches
  • Switch Type: Paddle switch
  • Body Material: Glass reinforced polymide resin
  • Gear Housing: Die-cast aluminum
Warranty
The Hitachi G12SS Angle Grinder comes with a 1-year limited warranty. This warranty covers the product in case of any manufacturing defects or issues that may arise under normal usage conditions. In the event that you experience any such issues within the warranty period, you can claim the warranty. The process generally involves contacting Hitachi's customer service with details about the issue and your product. Usually, you would need to provide proof of purchase, such as a receipt, to validate your claim. Always remember to keep the original purchase documents in a safe place for this purpose.
Hitachi G10SS and G12SS Disc Grinder Instruction Manual (EN, FR, ES)
Hitachi G 10SS, G 12SS and G 13SS Disc Grinder Handling Instructions (SV, DA, NO, FI, EN)
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 21
Past 30 Days: 95
All Time: 1,358
