Up to 20% off select tools
No Image
This wiki is missing a device image. Help improve this page by uploading one!
2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Models
EC2610E
Background
The Hitachi EC2610E is a portable air compressor that was introduced in 2016 and later discontinued. Its primary functions include supplying high-pressure compressed air to fill gas cylinders, to supply HVAC control systems, and to power pneumatic HVAC systems.
The air compressor is built with a 5.5 HP Honda GX160 gas engine, providing a reliable power source. It has a maximum air pressure capacity of 145 PSI, air delivery of 9.5 CFM at 90 PSI, and an air tank capacity of 8 US gallons. It features a cast iron air-cooled pump and a control panel on the baseplate for monitoring and adjusting air pressure. The compressor also includes an oil-lubricated pump, which can reduce wear and tear. Additionally, it has rubber vibration isolators to help lessen noise, maintaining a noise level of 69 dB. It measures 41.5 x 18.1 x 25.6 inches and weighs 158 lbs.
Technical Specifications
  • Power source: 5.5 HP Honda GX160 gas engine
  • Air tank capacity: 8 US gallons
  • Air delivery: 9.5 CFM at 90 PSI
  • Maximum pressure: 145 PSI
  • Noise level: 69 dB
  • Dimensions: 41.5 x 18.1 x 25.6 inches
  • Weight: 158 lbs
Warranty
The Hitachi EC2610E air compressor is covered by a 2-year consumer warranty. This warranty is intended to protect against defects in materials and workmanship. Please note that this warranty is applicable only to the original purchaser. It is important to be aware that any damage resulting from misuse or improper maintenance is not covered under this warranty. To claim the warranty, you would typically need to provide proof of purchase and may need to return the product for inspection. Always remember to check the specific warranty claim process with the manufacturer or your retailer.
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 34
All Time: 372
