Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
TE76P
Background
As a part of Hilti's extensive line of professional grade power tools, the Hilty Rotary Hammer TE 76 is specifically engineered for construction and industrial applications. This Hilti tool is known for its durability and performance.
This specific model of the TE 76 from 2015 is highlighted for the Active Torque Control (ATC) safety feature. This system for the torque control enhances the safety of the operator by shutting the motor off when detecting sudden torque, preventing kickback.
Finally, this device also includes features such as vibration reduction and an ergonomic design that makes it a durable, long-lasting and reliable tool.
Identification
It is about 20 inches long and 18 pounds in weight. This is distinguishable from other models because it includes the active torque control switch near the handle, the specific cooling vents, and specific branding placement on the shell's casing. This device does not come in more than one color scheme, only the typical red and black. The key identifier includes the Hilti logo placed on the side the active torque control switch with the specific controls and updated features. The model number is usually printed near the motor housing on the main grip to be easily visible.
Technical Specifications
Physical
  • Dimensions: 20"L x 4.5"W x 9.1"H
  • Weight: 18 lbs (8.1 kg)
  • Red and black D-handle with soft grip
Performance/Power
  • Input power 1400 watts
  • Rated for 120V
  • Impact torque 8.1 ft-lbs
Features/Accessories
  • Adjustable speed control for lighter use
  • Active torque control (ATC) safety feature, reducing kickback
  • Automatic overload control, protecting the device if it overheats
Additional Information
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 54
All Time: 631
