Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
DG 150
Background
The Hilti Diamond Grinder DG 150 was released in 2017 and discontinued shortly after the DGH 150 was released in 2021. The DG 150 is a special concrete grinder used in construction projects by concrete finishers for polishing hard concrete surfaces, removing paint and coatings. The Hilti Diamond Grinder is available in the North American, South American, European, Asian, African, and Australian markets. The retail price that was listed on the Hilti manufacturer’s site in 2017 was CAD$4,000.00.
The DG 150 diamond grinder is more durable and has a larger motor compared to a traditional angle grinder which allows it to easily remove rough concrete surfaces. The Hilti diamond grinder has two speed settings: Setting I, has a maximum speed of 4700 RPM. This setting is mainly used for grinding soft materials such as paint coatings on cement rendering. Setting II, has a maximum speed of 6600 RPM and is used for grinding hard mineral materials such as concrete, screed or rock. It also has a built-in vacuum installed into the grinder so dust particles can travel away from the surface that is being polished.
The DG 150 device has no recorded failures or manufacturer recalls. Hilti provides a 20-year materials and workmanship warranty and 2-year wear and tear coverage. The component most prone to failure is the diamond cup wheel which will need to be replaced after extended use.
Identification
To identify the Hilti diamond grinder DG 150 (2017), it’s important to look for a red colored device with a black handle and a white logo with Hilti DG 150 on the center of the device. The Hilti diamond grinder has a rectangular base with a side handle on the top used for controlling the device. On the rear of the device there is another handle used to hold the device, control its speed, and turn it on/off. The guard for the diamond cup wheel is located at the very front of the device and on the bottom of the guard there is a spindle and clamping flange which is used to hold the diamond cup wheel. This device has an LED indicator lamp located on both sides of the device by the main handle used to power the device. This special design feature makes it easy to distinguish from other diamond grinders. The dimensions of the device are: (L x W x H) 19.7 x 9.8 x 9.1 inches and the model number of this device is: 369388. The serial number can be found on the back of the device underneath the main handle.
The differences between the older model Hilti DG150 (2017) and the newer model Hilti DGH 150, is that the newer models are larger have a bulkier base with rough edges and a larger handlebar used for controlling the device. Also, the handle in the rear of the device has a connector for dust extraction.
Technical Specifications
Dimensions (Metric) (W x D x H)
·       Machine: 17.8 x 43.2 x 79.3 cm. [1]
·       Weight
o   Machine weight: 4.1 kg. [1]
Electrical Specifications
Voltage
110V
Rated current
16A
Power input
1,760W
Rated frequency
50/60Hz
Voltage
230V
Rated current
9.2A
Rated input
2,100W
Rated frequency
50Hz
·       Power connection: 110V – 230V, 50/60 Hz.
·       Current: 16A – 9.2A.
·       Power consumption: 1,760 – 2,100 W.
Power specifications
·       Rated speed, speed I: 4,700/min. [1]
·       Rated speed, speed II: 6,600/min. [1]
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 40
All Time: 910
