Up to 20% off select tools
Guides
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The HP Pavilion 15-cs3073cl was released in 2020 by Hewlett-Packard, later HP, Inc. It was produced for personal and professional use, with versatility in mind. The HP Pavilion 15-cs3073cl is an all-purpose device built for productivity and recreation, aimed at professionals, students, and those in between.
This laptop provides a mid-range option for those wanting a balance of features. The 10th Gen Intel Core i7 processor and 16 GB RAM ensure smooth transitions between different applications, such as projects, gaming, and web browsing, while the 1 TB of storage provides space for a vast number of photos, songs, documents, and files. Also highlighted is the NVIDIA MX250 graphics and the 15.6-inch Full HD touchscreen, resulting in vibrant visuals and wide-viewing angles.
The HP Pavilion 15-cs3073cl started being phased out in 2024 to pave the way for the AI-powered HP “Omni” series, which would aid in streamlining HP's product line. Its features were considered outdated, and the new series allowed for upgrades and new technology.
Source: Wikipedia
Identification
To identify the HP Pavilion 15-cs3073cl, the label on the bottom will have the product name, model number, and serial number. This information is also available by using the Fn + Esc keyboard shortcut to open the HP System Information window.
The HP Pavilion 15-cs3073cl has a sleek, modern design with an all-metal body. The cover and keyboard frame feature a "fog blue" sandblasted anodized finish, with a painted finish on the base. The laptop also has an elevated, backlit keyboard with a touch control touchpad, along with a 15.6-inch Full HD (1920 x 1080) IPS display screen.
Sources: Linnstech, Walmart
General
  • Operating System: Windows 10 Home (64-Bit)
  • Power Supply: 65 W with
  • Dimensions: 14.23 x 9.66 x 0.7” / 36.14 x 24.54 x 1.78 cm
  • Weight: 4.24 lb / 1.93 kg
  • Security: Kensington Lock Slot
Performance
  • CPU: 1.3 GHz Intel Core i7-1065G7 Quad-Core
  • Maximum Boost Speed: 3.9 GHz
  • L3 Cache: 8 MB
  • Installed RAM: 16GB
  • Buffered Memory: No
  • Graphics Type: Dedicated
Display
  • Panel Type: IPS-Type LCD
  • Display Size: 15.6”
  • Aspect Ratio: 16:9
  • Native Resolutions: 1920 x 1080
  • Touchscreen: Yes
  • Finish: Glossy
  • Maximum Brightness: 250 nits / cd/m^2
  • Color Gamut: 45% NTSC
  • Variable Refresh Technology: No
  • Viewing Angle (H x V): 178 x 178°
Storage and Expansion
  • Total Installed Storage: 1 TB
  • Optical Drive: No
Inputs / Outputs
  • Ports: 2 x USB-A 3.0 / 3.1/3.2 Gen 1
  • USB-C: 1 x USB 3.0 / 3.1/3.2 Gen 1
  • Display I/O: 1 x HDMI 1.4b Output
  • Audio I/O: 1 x 1/8” / 3.5 mm Headphone/Microphone Input/Output
Communications
  • Network I/O: 1 x RJ45 (Gigabit Ethernet)
  • Wi-Fi: Wi-Fi 6 (802.11 ax); Dual-Band (2.4 & 5 GHz)
  • MU-MIMO Support: 2 x 2
  • Bluetooth: 5.0
  • GPS: No
  • NFC: No
  • Webcam: User-Facing: 720p
Battery
  • Battery Chemistry: Lithium-Ion
  • Capacity: 3-Cell: 41 Wh
Keyboard & Mouse
  • Keyboard: with Backlight, Number Pad
  • Pointing Device: TouchPad
Source: B&H
Additional Information
Author
with
Kris Rodriguez
322,589 Reputation
1 Guide authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
Past 24 Hours: 7
Past 7 Days: 20
Past 30 Days: 59
All Time: 1,643
