Up to 20% off select tools
Guides
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The dimensions of this laptop are: 13.15in(L) x 9.45in(D) x 1.34in(minH)/ 1.57in(MaxH). The case is moonlight white with a shiny finish. It weighs 5.35 pounds.
Identification
If you are not sure if your device is an HP Pavilion dv4-2045dx, you can determine your model number through the systeminfo command. To run the command, open your console through the following steps:
  1. Hold down the Windows key (on this model, between the Fn button and left Alt button) and press R. This will open the Run box.
  2. Type “cmd” and press Enter. Your console should now be open.
  3. Type “systeminfo” and press Enter. Wait for a few seconds while your device retrieves the information.
  4. The console should now be displaying your system specifications. Look for “System Model,” which should be between “System Manufacturer” and “System Type.” If it says “Pavilion dv4-2045dx” or something similar, this guide applies to you.
Also, the model number might be labeled on a sticker located on the bottom of the laptop.
Additional Information
Official Page
Wikipedia
CNET Review
HP External USB DVD Drive Datasheet
HP Notebook 6-Cell Battery Product Information Sheet
Author
with
Megan Todd
612 Reputation
4 Guides authored
Baylor, Team 6-8, Williams Fall 2015 Member of Baylor, Team 6-8, Williams Fall 2015
BU-WILLIAMS-F15S6G8
3 Members
60 Guides authored
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 41
All Time: 5,553
