4 Answers 2 Score |
My faithful Laserjet 1200 printer will no longer print. |
3 Answers 0 Score |
Paper feed picks up second sheet before finishing the first |
1 Answer 1 Score |
Black vertical lines printing |
2 Answers 2 Score |
The paper will not feed |
Documents
Background and Identification
HP LaserJet is a line of laser printers manufactured by HP. The HP LaserJet 1200 is a monochrome laser printer in this series. The original HP LaserJet was actually the first desktop laser printer in the world, introduced in 1984.
The HP LaserJet 1200 can hold up to 260 sheets of paper. The printer includes a Motorola ColdFire 90 MHz processor with 72 MB of RAM. The 1200 model has a maximum monthly duty cycle of 10,000 pages, and each printhead has a duty cycle of 2,500 pages.
The HP LaserJet 1200 includes the HP logo, which includes the letters “hp” in lowercase font in the center of the printer’s front face. The name “LaserJet 1200” is printed in the lower portion of the printer’s front face.
Laser printing is a process that was developed in the 1970s, and eventually replaced other forms of printing such as dot-matrix or daisy-wheel impact printing. Laser printers work by passing a laser repeatedly over a negatively charged cylinder to create an ‘image’ out of charges. The cylinder, usually called a drum, then collects electrically charged ink (toner), and then presses it to the paper, creating the image. Finally, the paper and ink are both heated to fuse them together. This process makes high-resolution images and can cope with a huge variety of patterns, allowing people to print many different fonts and images.
Technical Specifications
GENERAL:
- Printer Type: Personal printer - laser - monochrome
- Form Factor: desktop
- Manufacturer: HP
POWER DEVICE:
- Voltage Required Margin: ± 10%
- Type: power supply
- Nominal Voltage: AC 120/230 V
- Frequency Required: 50/60 Hz
- Power Consumption Operational: 285 Watt
- Form Factor: integrated
PRINTER:
- Technology: laser
- Print Speed: Up to 15 ppm - B/W - Legal (8.5 in x 14 in)
- Connectivity Technology: wired
- Interface: Parallel, USB, LAN
- PostScript Support: standard
- Language Simulation: PCL 5E, PCL 6, PostScript 2
- Fonts Included
- 45 x scalable
- 35 x PostScript
- Type: personal printer
- Max H-Document Size: 8.5 m
- Max V-Document Size: 14 in
- Media Type: cards, envelopes, plain paper, transparencies
- Media Sizes: A4 (8.25 in x 11.7 in), A5 (5.83 in x 8.25 in), B5 (6.93 in x 9.83 in), Executive (7.25 in x 10.5 in), Legal (8.5 in x 14 in), Letter A Size (8.5 in x 11 in)
- Envelope Sizes: Com-10 (4.13 in x 9.5 in), International C5 (6.38 in x 9 in), International DL (4.33 in x 8.66 in), Monarch (3.87 in x 7.5 in), US No 10 (4.1 in x 9.5 in)
- Card / Label Sizes: US 3 x 5 Card (3 in x 5 in)
- Total Media Capacity: 260 sheets
POWER:
- Compliant Standards: EPA Energy Star
- Power Consumption Stand by / Sleep: 7 Watt
MISCELLANEOUS:
- Color: white
- Color Category: white
PROCESSOR:
- Processor: Motorola ColdFire 90 MHz
- Type: ColdFire
- Manufacturer: Motorola
- Clock Speed: 90 MHz
NETWORKING:
- Networking: Print server - external
- Network / Transport Protocol: AppleTalk, IPX/SPX, TCP/IP
- Data Link Protocol; Ethernet, Fast Ethernet, LocalTalk
- Compliant Standards: IEEE 802.3, IEEE 802.3u
INTERFACE PROVIDED:
- Type: none
RAM:
- Technology / Form Factor: SDRAM - DIMM 100-pin
- Max Supported Size: 72 MB
- Slots Qty: 1
- Empty Slots: 0
- Upgrade Rule: max 64 MB module
- Form Factor: DIMM 100-pin
- Technology: SDRAM
SOFTWARE / SYSTEM REQUIREMENTS:
- Peripheral / Interface Devices: USB port, parallel port
PRINTING:
- Max Resolution B/W: 1200 dpi
- Max Printing Speed B/W (ppm): 15 ppm
MEDIA HANDLING:
- Media Path Type: curved
- Max Media Size (Custom): 8.5 in x 14 in
- Media Type: Envelopes, transparencies, plain paper, cards
- Envelope Sizes: US No 10 (4.1 in x 9.5 in), International DL (4.33 in x 8.66 in), Com-10 (4.13 in x 9.5 in), International C5 (6.38 in x 9 in), Monarch (3.87 in x 7.5 in)
- Media Sizes: Letter A Size (8.5 in x 11 in), Legal (8.5 in x 14 in), Executive (7.25 in x 10.5 in), A4 (8.25 in x 11.7 in), A5 (5.83 in x 8.25 in), B5 (6.93 in x 9.83 in)
- OS Required: Apple MacOS 8.6, Apple MacOS 9, Microsoft Windows 2000, Microsoft Windows Millennium Edition, Microsoft Windows NT 4.0, Microsoft Windows XP
DUTY CYCLE:
- Monthly Duty Cycle (max): 10000 pages
- Cartridge / Printhead Duty Cycle: 2500
- Cartridge / Printhead Included Qty: 1
ENVIRONMENTAL PARAMETERS:
- Sound Emission: 56 dB
- Min Operating Temperature: 50 °F
- Max Operating Temperature: 90.5 °F
- Humidity Range Operating: 20 - 80%
COPIER:
- Copier Type: none
DOCUMENT & MEDIA HANDLING:
- Media Type Class: envelopes, film/transparencies, other, plain paper
- Media Size Class: A4/Legal
HEADER:
- Brand: HP
- Product Line: HP LaserJet
- Model: LaserJet 1200
- Localization: English
- Country Kits: United States
- Compatibility: Mac, PC
OFFICE MACHINE:
- Type: printer
- Functions: printer
- Monthly Duty Cycle Range (Printer Class): 1,000 - 9,999 pages
- Printing Technology: Laser
- Printing Output Type: monochrome
INTERFACE REQUIRED:
- Connector Type: 36 pin Centronics, 4-pin USB Type B, RJ-45
- Gender: female, male
- Connector Qty: 1
- Type: LAN, USB 2.0, parallel
- Total Qty: 1
DIMENSIONS & WEIGHT:
- Width: 16.3 in
- Depth: 19.2 in
- Height: 9.9 in
- Weight: 18.3 lbs
EXPANSION BAYS:
- Type: none
SLOT REQUIRED:
- Type: none
PRINTER OUTPUT:
- Max Speed: 15 ppm
- Media Size: Legal (8.5 in x 14 in)
- Output Quality: B/W
SOFTWARE:
- Type: Drivers & Utilities, HP FontSmart
PRINTER MEDIA:
- Media Load Type: automatic
- Media Feeder Qty: 1
- Media Feeder Max Format: Legal (8.5 in x 14 in)
- Media Feeder Capacity: 10 sheets, 250 sheets
PRINTER FONTS:
- Font Included Type: PostScript, scalable
- Fonts Included Qty: 35, 45
PC CONNECTIVITY:
- Interface: LAN, USB, parallel
SERVICE & SUPPORT:
- Type: 1-year warranty
SERVICE & SUPPORT DETAILS:
- Type: limited warranty
- Service Included: parts and labor
- Full Contract Period: 1 year
