Up to 20% off select tools
Medical Equipment
Neither iFixit nor this repair information is endorsed by or affiliated with the medical device manufacturer.
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Background and Identification
The HK Surgical Klein Touch Pump is a device manufactured for professional physicians in a surgical setting that aims to deliver high volumes of tumescent anesthesia. This specific model features an LCD touchscreen that allows physicians to inputs rates at 0.01 increments. The Klein pump boasts the only infiltration pump on the market with a non-conductive roller head, which increases safety during necessary procedures. The HK Surgical Klein Touch Pump is versatile in a fashion that allows the physician to operate the device from the LCD screen or one of the three-foot pedals. The major advantage of this product is that maximizes patient comfort all while reducing physician infiltration time.
Pump Features
  • Display: Color Graphic LCD
  • Modes of Operation: Toggle, Persistent, and Trigger
  • Dual air-activated footswitches with 12 ft hose
  • Leakage Current within IEC 60601-1
Technical Specifications
  • Maximum Motor Speed: 450 rpm
  • Holding Torque: 294 in-oz (2.08 N-m)
  • Flow Rate: Up to 1000 mL/min (varies depending on tubing set, connected cannula, and pump speed)
  • Power Requirements: 100-240 VAC (Inlet Hospital power cord IEC 320)
  • AC Frequency: 50-60 HZ single phase
  • Main Power Input Fusing: 2.5A, 150V
  • Protection against electric shock: Class I, Type B
  • Enclosure rating: Ordinary Equipment
  • Dimensions: 11” x 10 (3/4) “x 5”
  • Weight: 8.4 lbs
  • Liquid ingress rating: IPO - No protection
Warnings
  • Use only in temperatures from 4˚C-40˚C
  • Use only in non-condensing humidity ≤ 80% of relative humidity up to 31˚C and linearly down to 50% relative humidity at 40˚C.
  • To ensure power grounding, make sure to use the only cordage that is terminated in hospital-grade plugs.
  • Store and ship product between -20˚C to 50˚C
Additional Resources
The following links are official retailers and reputable sources for the device.
Visual Overview of Device
The above video gives a video overview of the product that covers how to properly operate the product as well as the associated accessories.
Quick Usage Guide
The above video gives a very brief explanation of how to insert tubing into the device and setting the flow rate.
Notes
*Information is for the “HK Surgical Klein Infiltration Pump” however both models are very similar save the LCD on the “HK Surgical Klein Touch Infiltration Pump”. The LCD allows for more precise control only.
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 36
All Time: 751
