10 Diagrams
Models
T-4-HS18-
Background and Identification
The Ground Hog T-4 - 18" is a mechanical chain trencher. Trenchers vary in size and power depending on the size and type of the surface that is being dug out. They are used to dig trenches for many different uses, such as pipe or cable laying and drainage channels. Chain trenchers use a blade similar to a chainsaw to cut narrow, deep trenches with a series of teeth that hook into the ground and pull the material out and away from the trench.
This machine advertises easy to use controls and accurate trenching that allows the user to work close to walls and fences. It is operator propelled, which means that the user can turn the tall handle on the back to control the direction of the trench. More operating information as well as safety warnings for this trencher can be found in the operating manual here.
Technical Specifications
  • Engine: Honda GX160UT2
  • Heavy gauge steel unibody frame
  • Powder coated finish
  • 5 H.P. engine
  • Centrifugal clutch w/ needle bearings and all metal drum and shoes
  • Carbide tipped Shark Teeth or carbide tipped Bullet Teeth
  • Solid roller digging chain
  • Wide pneumatic tires with tubes
  • Part Number / SKU: T-4-HS18
Additional Information
Ground Hog Product Page
Trencher - Wikipedia
T-4 Trencher Parts
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 27
Past 7 Days: 205
Past 30 Days: 875
All Time: 43,390
