2 Diagrams
1 Answer 2 Score |
Where can I find the proper bit |
1 Answer 0 Score |
Pivot handle part 57. Is broken, where can buy? |
Documents
Models
HD99H
Background and Identification
The Ground Hog Auger (model HD99-H) is a towable hydraulic Earthdrill that require no torque from the operator. The hydraulic hoses are protected within the machine’s frame. The Earthdrill also includes a six-gallon per minute hydraulic pump. The HD99-H model can dig holes with any auger with a 7/8-inch square auger drive up to an 18-inch diameter. The Earthdrill includes a red eight-inch auger attached to the machine.
The HD99-H model has three different handlebar positions, two for normal drilling and one for close-up drilling next to an obstacle or fence and transporting the machine. The auger’s drilling head pivots from side to side for easier drilling on irregular terrain. The HD99-H model features a 9-horsepower Honda GX270 gasoline-powered engine. The engine produces 275 foot-pounds of torque and a maximum auger speed of 140 rotations per minute. The engine frame also swivels to keep the engine level. The auger has variable forward speed and reverse auger rotation (which is useful if the auger becomes stuck).
The Ground Hog Auger (model HD99-H) includes 5.70- by 8-inch pneumatic highway-rated tires for towing and maneuvering. The HD99-H model can be identified by its yellow color and the number model HD99-H in black font along the main arm of the auger. The manufacturer’s name, “Ground Hog,” is also printed in red font with a black background on the auger’s main arm. It also includes a towbar with a 2-inch hitch coupler and safety chains.
Technical Specifications
- Acme Tools Air Shipment Restricted: N
- Acme Tools Brand Name: GROUND HOG
- Acme Tools Part Number: HD99-H
- Assembled Weight (lbs): 295
- Case Included: No
- Chuck Design: Not Applicable
- Chuck Size: Not Applicable
- Color / Finish: Yellow/Red
- Country of Origin (numeric): USA
- Handle Material: Steel
- Horsepower (hp): 9
- Housing Material: Steel
- Hydraulic Maximum Flow Rate (gpm): 6
- Internal Supplier Part #: HD99-H
- Internet Product Code (IPC): B41C07F34CE
- MFG Model # (Series): HD99-H
- MFG Part # (OEM): HD99-H
- Maximum Drill Diameter (in): 18
- Maximum RPM (No Load): 140
- Minimum Drill Diameter (in): 2
- Number of Speeds: Variable
- Overall Length (in): 100
- Package Weight: 325
- Product Name: HD99 Hydraulic Earthdrill
- Reverse: Yes
- Side Handle: No
- Tool Handle Type: D
- UPC: 408099000015
- Variable Speed: Yes
- Warranty Type: 6 Month
- Weight (lbs): 295
- Working Pressure (psi): 1500
- globalTradeItemNumber (GTIN): 00408099000015
Additional Information
- Ground Hog Ground Augers HD99-H Product Page
- Ground Hog Ground Augers HD99-H Official Website
- Home Depot: Ground Hog Ground Augers HD99-H
- Engine: Honda GX270UT2
Ground Hog HD99 Hydraulic One-Man Earth Drill Operator's Manual
