Up to 20% off select tools
Documents
he Ultra QuickShot is breakthrough technology, designed to deliver higher quality and provide results faster. Created for the perfect airless finish, while virtually eliminating spits. Built with extreme spray control to quickly adjust pressure for every application.
The industry's most portable sprayer gives you the ability to spray in the tightest of areas with precision and the highest control. Spray the widest range of architectural coatings, from water based paints, to solvents, and flammable based materials. Perfect for small jobs such as cabinets, doors, trim, soffits, gutters and more.
  • Instant Response Electric Powered Gun Virtually Eliminates Spits
    • Reduce fatigue with industry's lightest trigger pull
    • Smallest, lightest airless gun ever built
    • Responds instantly to produce the best finish
  • On-Demand Precision Flow-Control System
    • Quickly adjust material flow for extreme airless spray control
    • Easily dial-in to your desired pressure from 100-2,000 psi
  • 6 ft Flexible Hose For Full Reach & Easy Hose Management
    • Easily prime, change colors, and clean in seconds
    • Gun and hose hold only 1 oz of coating
  • QuickShot ProConnect Airless Piston Pump
    • Durable long-life triple piston pump
  • 32 oz Pour-N-Go Cup
    • Easy fill design - refill on your hip
    • Spray small amounts FAST
  • Power to Take on Every Small Job
    • Comes with two DEWALT 20V Lithium-ion batteries
    • Spray up to one gallon on each battery
  • Ultimate Hands-Free Portability With Belt and Holster Attachment
Author
with
nicO
15,990 Reputation
88 Guides authored
Global Fixers Member of Global Fixers
Community
74 Members
3,048 Guides authored
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 39
All Time: 908
