Up to 20% off select tools
3 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Background and Identification
This product is a large texture sprayer, meant for painting large rough surfaces. It is manufactured by Graco, a fluid-handling systems manufacturer based in Minneapolis, Minnesota. Air-powered products are a specialty of the Graco company. In fact, their first product in 1926 was an air-powered grease gun that worked in cold weather, unlike hand powered models. After this first success, the company expanded to other lubricant handling products. Today, they offer a variety of paint sprayer options, from small handheld devices to large sprayers for outdoor use.
The front label of this paint sprayer has the description ‘TexSpray RTX 5000 PI. RTX5000pi is the model number that appears in the operating manual, but the Graco product page has another model number, 17H575, which can also be used to identify this product. The sprayer is compatible with several different materials, including “acrylic texture, drywall mud, simulated acoustic, [and] water-based material,” according to the product page.
Technical Specifications
  • Model: TexSpray RTX
  • Series: 5000PI
  • Type: Air-Assisted Airless Sprayer
  • Assembled Depth: 33.75 in
  • Assembled Width: 22.75 in
  • Assembled Height: 39.5 in
  • Weight: 164 lbs
  • Maximum Hose Length: 100 ft
  • Cordless/Corded: Corded
  • Power Source: Electric
  • Power Rating: 2 HP
  • Amperage: 15 amps
  • Voltage: 120 volts
  • Hopper Capacity: 15 gal
  • Maximum Flow Rate: 5.0 gal/min
  • Maximum Sound Pressure Level: 81.8 dB(A)
  • Maximum Tip Size: 0.473 in
  • Maximum Working Pressure: 0.7 MPa (100 psi)
  • Minimum Generator Power: 7500 W
Additional Information
Home Depot Rental Page
Operating Manual
Graco Product Page
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 48
All Time: 3,076
