3 Diagrams
1 Answer 1 Score |
How do you replace the pump hose inside the unit? |
1 Answer 0 Score |
Svc problem with pressure |
Documents
Background and Identification
The TexSpray RTX2000pi Standard Interior Texture Sprayer is designed for residential and repaint contractors. The sprayer is made by Graco and is made for spraying orange peel, splatter, knockdown, and popcorn texture on walls and ceilings.
The RTX2000pi includes a Graco RotoFlex II pump designed to provide uniform coverage with flow-through design. The Flex Change Pump System allows users to switch out a pump without the use of any tools. This model has a 5 gallon per minute output and can hold up to 13 gallons of material. The material flow can be adjusted with gauge dials for spraying thicker or thinner materials. This model also includes a SmartStart system that allows a soft start to eliminate material blast.
The RTX2000pi model sprays simulated acoustic and drywall mud with several finishes from included nozzles. The nozzles include 3mm, 4mm, 6mm, 8mm, 10mm, and 12mm round nozzles, 3mm, 4mm, 6mm, 8mm, 10mm, and 12mm WideTex adapter nozzles, and XL Wide tips. The machine also includes a 1-inch by 25-foot material hose and a 3/8-inch by 25-foot air hose. The Wide Tex tips can spray up to 20 percent more material than the standard round nozzles.
The RTX1400si includes the name “TexSpray” in silver capital letters on the front of the material tank above the name “RTX 2000pi.” The sprayer’s frame is a dark blue color and the engine cover is grey plastic. The machine also includes two large wheels for maneuverability.
Technical Specifications
Dimensions:
- Air hose length (ft.): 25
- Product Depth (in.): 24.25
- Product Height (in.): 41.6
- Product Width (in.): 22.2
Details:
- Compressor required: No
- Flow rate (gallons per min.): 5.0
- Hopper capacity (gallons): 13
- Hopper type: gravity feed
- Included: Hose Included, Spray Gun Tip included
- Interior/Exterior: Interior
- Maximum operating pressure (psi): 100
- Minimum operating pressure (psi): 0
- Number of Spray Settings: 99
- Paint Sprayer Type: Cart
- Paint Sprayers Product Type: Texture
- Performance Features: Air Flow Valve, Flow Control, Fluid Control Valve, Pressure Relief Valve
- Product Features: Gravity Feed Hopper
- Product Weight (lb.): 86 lb
- Recommended Annual Usage (GAL./YEAR): 750
- Trigger Configuration: Two Finger Trigger
- Usage Type: Heavy Duty
Additional Information
- Graco Paint Sprayers RTX2000pi Home Depot Product Page
- Graco Paint Sprayers RTX2000pi Operation and Parts Manual
- Graco Texture Sprayers Guide
- Graco Paint Sprayers RTX2000pi Quick Start Guide
Graco RTX1400si, RTX2000pi & RTX2500pi Interior Texture Sprayers Operation and Parts Manual
