Up to 20% off select tools
Guides
4 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Models
17C325
Background and Identification
The Graco Paint Sprayer model 17C325 is a portable electric airless sprayer that is compatible with coating or paint. This model has one gun, and is intended for use on large architectural surfaces. It is meant for professional use only, and is manufactured by Graco, a fluid-handling systems manufacturer based in Minneapolis, Minnesota.
Air-powered products are a specialty of the Graco company. In fact, their first product in 1926 was an air-powered grease gun that worked in cold weather, unlike hand powered models. After this first success, the company expanded to other lubricant handling products.
Airless spray painters like the Graco Paint Sprayer 17C325 have several advantages, mainly efficiency and good coverage. They can cover large spaces in a short period of time, and the high-pressure application ensures that even rough surfaces will be well-covered. This makes the machine ideal for use on concrete, stucco, or other architectural surfaces.
Technical Specifications
  • Series: 230 PC
  • Model: RentalPro
  • Type: Airless Sprayer
  • Weight (kg): 30
  • Frame Configuration: Hi-Boy
  • Maximum Hose Length (m): 15
  • Maximum Tip Size (cm): 0.0584
  • Fluid Outlet Size (cm): 0.635
  • Fluid Outlet Thread Type: NPSM
  • Outlet Paint Filter: 60 Mesh Stainless Steel Screen
  • Maximum Flow Rate (L/min): 2.16
  • Maximum Sound Pressure Level (dB(A)): 90
  • Maximum Working Pressure (MPa): 20.7
  • Minimum Generator Power (W): 3500
  • Power Rating (HP): 1.0
  • Power Source: Electric
  • Pressure Control Type: Mechanical Pressure Control
  • Pump Mount Type: ProConnect
  • Pump Rod Type: Chromex
  • Pump Sleeve Material: Hardened Steel
  • Pump Type: Endurance
Additional Information
Product Page (Full List of Technical Specs)
Operating Manual
Graco - Wikipedia
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 19
Past 7 Days: 119
Past 30 Days: 597
All Time: 45,183
