Up to 20% off select tools
4 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
17C301
Background and Identification
This is a medium duty paint sprayer that is intended to be used by a professional on architectural painting projects. There are two model numbers listed in the operating manual: 17C301 and 25R758. However, the Graco website refers to this paint sprayer with the 17C301 model number.
Air-powered products are a specialty of the Graco company. In fact, their first product in 1926 was an air-powered grease gun that worked in cold weather, unlike hand powered models. After this first success, the company expanded to other lubricant handling products.
Airless spray painters like the Graco Paint Sprayer 17C301 have several advantages, mainly efficiency and good coverage. They can cover large spaces in a short period of time, and the high-pressure application ensures that even rough surfaces will be well-covered. This makes the machine ideal for use on concrete, stucco, or other architectural surfaces.
Technical Specifications
  • Series: 210 PC
  • Type: Airless Sprayer
  • Model: RentalPro
  • Compatible Material: Paint
  • Weight (kg): 27
  • Power Rating (HP): 5/8
  • Power Source: Electric
  • Fluid Outlet Size (cm): 0.635
  • Frame Configuration: Lo-Boy
  • Maximum Flow Rate (L/min): 1.8
  • Maximum Sound Pressure Level (dB(A)): 90
  • Maximum Tip Size (cm): 0.0533
  • Maximum Working Pressure (MPa): 20.7
  • Minimum Generator Power (W): 3000
  • Number of Guns: 1
  • Outlet Paint Filter: 60 Mesh Stainless Steel Screen
  • Pressure Control Type: Mechanical Pressure Control
  • Pump Mount Type: ProConnect
  • Pump Rod Type: Chromex
  • Pump Sleeve Material: Hardened Steel
Additional Information
Product Page (Full Technical Specs)
Main Product Operating Manual
Spray Gun Operating Manual
Graco - Wikipedia
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 10
Past 7 Days: 119
Past 30 Days: 514
All Time: 36,121
