Up to 20% off select tools
No Image
This wiki is missing a device image. Help improve this page by uploading one!
3 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Models
210PC
Background
The Graco Paint Sprayer 210PC is an electric airless sprayer. This machine is a part of the Pro210ES series. The 210PC operates on 120V and has a 1 HP DC motor, which provides 0.75 kW of power. It has a working pressure of 20.7 MPa and can deliver up to 1.8 liters per minute of paint. It comes with a SG3 spray gun and a 515 spray tip, which can vary in size from 0.009 to 0.021 inches.
The sprayer's frame measures 71.8 cm x 59.1 cm x 52.1 cm and weighs 31 kg. Its fluid outlet size is 6.35 mm with NPSM thread and it can support up to 50 meters of hose. It is designed for small residential, commercial, and shop painting projects. The machine's Endurance pump can handle a variety of coatings including latex paints, stains, enamels, block fillers, and primers. The sprayer also comes with a 50 ft Duraflex hose, a tip guard, a startup guide, and TSL lubricant. Furthermore, it has an integrated filter screen and pressure control. The SG3 spray gun is designed to provide comfort and control during use.
Technical Specifications
  • Model Number: 210PC
  • Product Type: Electric Airless Paint Sprayer
  • Power Source: 120V
  • Motor: 1 HP DC motor providing 0.75 kW of power
  • Max. Working Pressure: 20.7 MPa (3,000 psi)
  • Flow Rate: Up to 1.8 liters per minute
  • Spray Gun: SG3
  • Spray Tip: 515 with a tip size range from 0.009 to 0.021 inches (0.23 to 0.53 mm)
  • Amperage Rating: 13A
  • Frame Dimensions: 71.8 cm x 59.1 cm x 52.1 cm (28.25 in x 23.25 in x 20.5 in)
  • Weight: 31 kg (69 lb)
  • Fluid Outlet Size: 6.35 mm (1/4 in) NPSM thread
  • Hose Support: Up to 50 meters (200 ft) of hose
Warranty
The Graco Paint Sprayer 210PC comes with a 1-year warranty provided by the manufacturer, Graco. This warranty covers any defects that may arise from materials and workmanship. However, it's important to note that wear items including packings, cups, and tips are excluded from the warranty coverage. The warranty also does not cover any damage that results from abuse, misuse, or improper maintenance of the product. In order to claim the warranty, users are advised to consult the detailed warranty terms available on the Graco website.
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 40
All Time: 896
