Up to 20% off select tools
No Image
This wiki is missing a device image. Help improve this page by uploading one!
4 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
210ES
Background
The Graco Paint Sprayer 210ES is a piece of equipment designed for painting tasks. This machine operates on a 120V electric power source and uses a DC motor. Noteworthy technical specifications include a power rating of 746W, a single-phase amperage of 13A, a maximum working pressure of 3000 psi, and a maximum flow rate of 0.47 GPM. The fluid outlet size is 1/4 inches, and the device can accommodate hose lengths up to 200 ft. The unit weighs approximately 69 lb.
The 210ES has notable features that contribute to its functionality. It employs a ProConnect pump with an Endurance chromex pump rod and a hardened steel sleeve. The sprayer also possesses a mechanical pressure control system and a hi-boy cart frame configuration. Additionally, it comes with an SG3 spray gun and a 515 spray tip. The machine includes a 60 mesh stainless steel paint filter and durable wetted parts made from materials like stainless steel, acetal, and aluminum. During operation, the 210ES uses an electric motor to power a piston pump that propels paint from a source, through a hose, and out of the spray gun at high pressure. The mechanical pressure control allows for the alteration of spraying pressure up to 3000 psi.
Technical Specifications
  • Model Number: 210ES
  • Product Type: Electric Airless Paint Sprayer
  • Power Source: 120V electric
  • Motor Type: DC motor
  • Power Rating: 746W (1HP)
  • Amperage: 13A
  • Phase: Single phase
  • Maximum Working Pressure: 3000 psi (20.7 MPa, 207 bar)
  • Maximum Flow Rate: 0.47 GPM (1.8 L/min)
  • Fluid Outlet Size: 1/4 in (6.35 mm) NPSM thread
  • Maximum Tip Size: 0.021 in
  • Maximum Hose Length: 200 ft
  • Weight: 69 lb (31 kg)
Warranty
The Graco Paint Sprayer 210ES comes with a standard 1-year warranty from Graco. This warranty covers any defects in materials or workmanship that may arise. It's important to note, however, that the warranty does not cover regular wear and tear from normal use. To claim the warranty, the user would typically need to provide proof of purchase and contact Graco's customer service for assistance.
190ES/210ES Portable Electric Airless Sprayer Operation Manual (EN, FR, ES)
Graco 190ES/210ES/210ES Plus — Pulvérisateurs Airless sur pied et Hi-Boy, réparation
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 72
All Time: 545
