No Image
This wiki is missing a device image. Help improve this page by uploading one!
2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Models
17G177
Background
The Graco Paint Sprayer 17G177 is an electric airless paint sprayer. This product is part of Graco's ProX series of sprayers intended for a variety of uses, including commercial, industrial, and home use. The sprayer operates with a 0.75HP DC motor and a stainless steel piston pump with a maximum pressure of 3000psi. It has a flow rate of 0.34GPM and is compatible with tip sizes ranging from 0.009in to 0.017in. The product includes a 1/4in x 50ft Duraflex hose and weighs 27lbs. Its dimensions are 21.2in in height, 13.2in in width, and 15.1in in length.
The Graco Paint Sprayer 17G177 features a ProXChange pump for quick pump removal and adjustable pressure control. An SG3 spray gun, a TrueAirless 515 spray tip, a tip guard, and a 35 mesh inlet strainer are included. The product also comes with 8oz of pump armor storage fluid and accommodates a maximum hose length of 150ft. Its frame is mounted on a stand and it is compatible with one gun. The sprayer's wetted parts are made of various materials including stainless steel, aluminum, brass, carbide, nylon, PVC, polypropylene, and other engineered composites. The Graco 17G177 sprayer can be used for applying a range of coating materials including latex paints, primers, sealers, stains, varnishes and more. It is suitable for painting tasks, wood finishing, deck and fence staining, and other applications. It is recommended for up to 300 gallons per year and can be used by professional contractors, maintenance crews, production shops and DIY homeowners.
Technical Specifications
  • Model Number: 17G177
  • Product: Electric Airless Paint Sprayer
  • Power: 120V, 60Hz, 1 phase, 559W, 0.56kW
  • Motor: 0.75HP DC motor
  • Pump: Stainless steel piston pump with max pressure of 3000psi (207bar)
  • Flow Rate: 0.34GPM (1.3L/min)
  • Tip Sizes: 0.009in to 0.017in compatible
  • Hose: 1/4in x 50ft hose included
  • Weight: 27lbs (12kg)
  • Dimensions: Height 21.2in (539mm), Width 13.2in (335mm), Length 15.1in (384mm)
  • Material: Wetted parts made of stainless steel, aluminum, brass, carbide, nylon, PVC, polypropylene and other engineered composites
  • Intended Use: Applying a variety of coating materials including latex paints, primers, sealers, stains, varnishes and more
Warranty
The Graco Paint Sprayer 17G177 comes with a manufacturer's warranty valid for 1 year. This warranty covers the entire product. An exceptional feature of this product is that the pump, a critical component of the sprayer, has a lifetime warranty to the original owner. To claim the warranty, users should refer to the manual that comes with the product for detailed instructions and any limitations that may apply.
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 24
All Time: 295
