Up to 20% off select tools
No Image
This wiki is missing a device image. Help improve this page by uploading one!
3 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
17D163
Background
The Graco Paint Sprayer 17D163 is an electric airless paint sprayer, part of the Pro210ES series, designed for both residential and commercial use. This sprayer is powered by a 120V electric source and equipped with a DC motor. It has a power rating of 0.75 kW (1 HP) and operates at a maximum pressure of 207 bar (3000 psi), with a maximum flow rate of 1.8 L/min (0.47 GPM). The sprayer can accommodate a hose of up to 200 ft and supports a maximum tip size of 0.021 in. The pump, designed with a chromex rod, is mounted via the ProConnect system. The entire unit weighs 15 kg (34 lb).
The Graco 17D163 is versatile, capable of spraying various types of materials including lacquers, stains, enamels, and latex paints. It is equipped with an SG3 spray gun, and a 515 spray tip, capable of providing quality spray output with adjustable pressure control. The sprayer also includes a 50 ft Duraflex hose and a 60 mesh stainless steel paint filter, enhancing its functionality. The sprayer is suitable for a range of applications such as painting fences, decks, interior walls and ceilings, doors and trim, and is capable of supporting a 200 ft hose for larger projects.
Technical Specifications
  • Model Number: 17D163
  • Product Type: Paint Sprayer
  • Power Source: 120V electric
  • Motor Type: DC motor
  • Power Rating: 0.75 kW (1 HP)
  • Amperage: 13A
  • Maximum Pressure: 207 bar (3000 psi)
  • Maximum Flow Rate: 1.8 L/min (0.47 GPM)
  • Maximum Hose Length: 200 ft
  • Maximum Tip Size: 0.021 in
  • Pump Type: Endurance pump with chromex rod
  • Pump Mount: ProConnect
  • Frame: Stand mount
  • Weight: 15 kg (34 lb)
Warranty
The Graco Paint Sprayer 17D163 comes with a 1-year warranty that covers defects in materials and workmanship. However, this warranty is non-transferable. It's important to note that the warranty does not cover any damage that results from misuse, abuse, or alteration of the product. Additionally, wear items such as packings, seals, and tips are not included in the warranty coverage.
Graco 210 ES Electric Airless Sprayers Operation and Parts Manual
Graco 210 ES Electric Airless Sprayer Operation and Parts Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 26
All Time: 373
