Up to 20% off select tools
No Image
This wiki is missing a device image. Help improve this page by uploading one!
3 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
17C332
Background
The Graco Paint Sprayer 17C332 is an electric-powered device utilized for home improvement projects. It is capable of spraying various types of paints and stains on different materials such as wood, metal, drywall, and concrete. This unit operates on 120V AC, 60 Hz power, and can handle a maximum tip size ranging from 0.015" to 0.021". It is capable of delivering up to 0.47 GPM under a maximum pressure of 3000 PSI. The device comes with a 25-foot hose and weighs 17 lbs.
The Graco Paint Sprayer 17C332 employs an electric motor to propel paint from its container through the spray nozzle, producing a consistent spray pattern. It features a flexible suction tube that enables direct spraying from 1 or 5-gallon paint containers. An adjustable pressure control knob is included for fine-tuning the spray output. The device also incorporates a PowerFlush adapter, which can be connected to a garden hose for swift cleaning. It comes with a 25-foot paint hose, reversible spray tips of 0.015" and 0.021", and a contractor gun. The device is designed for spraying thin liquids such as stains, sealers, and latex house paints. It is also equipped with a portable cart base for easy maneuvering.
Technical Specifications
  • Power: 120V AC, 60 Hz
  • Maximum tip size: 0.015"-0.021"
  • Maximum delivery: 0.47 GPM
  • Maximum pressure: 3000 PSI
  • Hose length: 25 ft
  • Weight: 17 lbs
Warranty
The Graco Paint Sprayer 17C332 comes with a warranty that lasts for a duration of 1 year. This warranty is intended to provide coverage against any defects that may arise due to issues in the materials or the workmanship of the product. However, it's important to note that any damage resulting from misuse or improper maintenance won't be covered under this warranty. In order to claim the warranty, customers must present their receipt as proof of purchase, which is why it's recommended to keep it safely. To avail services under warranty, the unit needs to be returned to an authorized Graco service center.
Graco 490/495/595/395EU Pulvérisateurs électriques sans air — Fonctionnement et pièces
Graco 395/490/495/595 Electric Airless Sprayers Operation and Parts Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 24
All Time: 342
