Up to 20% off select tools
Guides
Documents
Models
GE2AE, GP4BC
Background
The Pixel 7 Pro is Google’s 2022 flagship smartphone and was announced on October 6th, 2022, alongside the Google Pixel 7. The phone offers features like 5G capability, up to 12 GB of RAM, up to 512 GB of onboard storage, and a 120 Hz 6.7” HDR10+ LTPO AMOLED display. It offers an IP68 rating and is equipped with a battery with a 5,000 mAh capacity. The Pixel 7 Pro runs on a Google Tensor G2 octa-core chipset with a Mali-G710 MP7 GPU. The Pixel 7 Pro starts at $899 USD.
Identification
The Google Pixel 7 Pro is available in the colors Obsidian, Snow, and Hazel depending on region and carrier. It has a slightly larger display than the Google Pixel 7 at 6.7 inches and the main camera is triple lens compared with the dual lens of the Pixel 7.
The model numbers for this Pixel are GP4BC and GE2AE. The best place to find the model number for this phone is on the original box or by following the instructions below:
Navigate to "Settings" >"About phone" then scroll down and tap on "Model & Hardware."
Repairability
For a detailed look at the pros and cons of repairing the Pixel 7 Pro, see the attached report.
Repair Snapshot Pixel 7 Pro
Technical Specifications
  • CPU: Octa-core (2x2.85 GHz Cortex-X1 & 2x2.35 GHz Cortex-A78 & 4x1.80 GHz Cortex-A55)
  • GPU: Mali-G710 MP7
  • Memory: 8/12 GB LPDDR5 RAM
  • Storage: 128/256/512 GB internal memory
  • Display
    • 6.7 inch panel
    • 1440 x 3120 pixels (~512 ppi)
    • LTPO AMOLED, HDR10+, 120Hz
  • Cameras
    • Main Camera: Triple-lens camera with 50 MP, f/1.9, 25mm (wide), 1/1.31", 1.2µm, 48 MP, f/3.5, 120mm (telephoto), 1/2.55", 0.7µm and 12 MP, f/2.2, 126˚ (ultrawide), 1/2.9", 1.25µm, AF
    • Front-facing Camera: 10.8 MP, f/2.2, 21mm (ultrawide), 1/3.1", 1.22µm
  • Ports and Connectivity
    • Wi-Fi 802.11 a/b/g/n/ac/6e, tri-band, Wi-Fi Direct, hotspot
    • 5G Sub 6GHz / mmWave, LTE
    • Bluetooth v5.2
    • GPS, GLONASS, BDS, GALILEO, QZSS, NFC
    • USB Type-C 3.2
  • Battery:
    • Li-Ion 5000 mAh battery
    • Fast charging 23W
  • Dimensions
    • Size: 162.9 x 76.6 x 8.9 mm (6.41 x 3.02 x 0.35 in)
    • Weight: 212 g (7.48 oz)
  • Additional Features
    • IP68 water/dust resistance rating (1 meter underwater up to 30 minutes)
    • Stereo speakers
    • Fingerprint (under display, optical)
    • Laser AF
Additional Information
Author
with
Dominik Schnabelrauch
268,200 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
Past 24 Hours: 47
Past 7 Days: 359
Past 30 Days: 1,757
All Time: 135,246
