Up to 20% off select tools
Background
Bring high-quality cooking tools to your home kitchen with the GoodCook Digital Instant Read Precision Kitchen Thermometer. Designed with home cooks in mind, this digital cooking thermometer measures between -4 and 482 degrees Fahrenheit and provides both Fahrenheit and Celsius readings, and the rapid-response design provides a fast and accurate reading in less than 3 seconds. The large backlit LCD screen makes it quick and easy to read the temperature, and the auto-off functionality helps to extend battery life. The convenient cooking guide on the back of the thermometer provides USDA recommendations to ensure beef, lamb, pork, ham, chicken, turkey, and more are prepared to the correct temperature and doneness level needed. It can also be used while making candy, chocolate, desserts, fried foods, and more.
With its flip-out probe design, built-in magnet, and hanging loop, this thermometer is easy to store anywhere around the kitchen when not in use, from drawers and utensil holders to the side of the refrigerator or grill. It is also IP65-rated, dust-tight, and water-resistant so you can leave it outside with your grilling supplies and wash it clean in the sink. This cooking thermometer is NSF-approved as well, making it great for use in commercial and food service kitchens.
This quick-response digital thermometer can accurately give you internal readings of your foods as you cook, in a fast 3-seconds. Use it on meats for food safety or for candy, oil, milk, and more, when knowing the temperature is necessary for best results. The sleek design is more compact than most folding thermometers and still loaded with features. A stainless steel probe opens a full 180° and turns on the thermometer. Close it to turn it off, which reveals a handy hanging loop when you cannot use the built-in magnet. A large illuminated LCD display is easy to read, and easily set in °F or °C with a push of a button. Our thermometer is waterproof and NSF certified to give you accurate readings between -4 to 482°F (-20 to 250°C), convertible with the touch of a button. A handy safe temperature guide is also imprinted on the handle for easy reference any time you’re cooking or grilling.
  • INSTANT READ KITCHEN THERMOMETER: Measures in both Fahrenheit and Celsius between -4 and 482 degrees Fahrenheit, and the rapid-response design provides a fast and accurate reading in less than 3 seconds
  • EASY-TO-READ LCD SCREEN: Large backlit LCD screen makes it quick and easy to read the temperature, and the auto-off functionality helps to extend battery life
  • CONVENIENT COOKING GUIDES: Allows you to prepare beef, lamb, pork, ham, chicken, turkey, and more to the USDA-recommended temperature and doneness level
  • EASY STORAGE WITH BUILT-IN MAGNET: Flip-out probe design, built-in magnet, and hanging loop allow it to be stored anywhere in the kitchen, from drawers and utensil holders to the side of the refrigerator or grill
  • IP65-RATED AND NSF-APPROVED: The thermometer is IP65-rated, dust-tight, and water-resistant so you can leave it outside with your grilling supplies and clean it in the sink, as well as NSF-approved for use in commercial and food service kitchens
Identification
This device can be identified by item model number 20553.
Technical Specifications
  • Dimensions: 8.62 in x 4.41 in x 1.38 in (W x L x H)
  • Weight: 3.03 Ounces
  • Model Number: 20553
  • ASIN: B089CL6B43
  • Manufacturer: Bradshaw Home
  • Battery: CR2032
  • Cleaning: Handwash Only
Features
  • Large illuminated LCD display with 5-min Auto shutoff
  • Waterproof (IP66) & dust tight
  • NSF Certified fold-out probe
  • Magnet:
  • Food Temperature Chart
  • Accuracy: ±2°F (±1°C)
  • Response Time: 3 seconds
  • Temperature Rating: -4 to 482F (-20 to 250C).
Additional Information
Author
with
Addison
3,165 Reputation
17 Guides authored
Past 24 Hours: 5
Past 7 Days: 40
Past 30 Days: 111
All Time: 2,343
