Up to 20% off select tools
9 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
242H
Background and Identification
The 242H EPIC™ Series hand-held Hole Digger features an all position, 4 Stroke engine. No more mixing oil with gas. No more separate fuel cans. And, no more smoky exhaust with a Honda® engine that meets current EPA emission standards. The 242H is built with professional features that make it ideal for both contractors and homeowners alike. Performance to dig up to an 8 inch (203 mm) diameter hole in a variety of soil classifications. Built with oversized ball bearings, heat treated shafts and precise, machine-cut gears designed to deliver long service life and high ROI. The unique, ergonomically engineered Power-GRIP™ operator handle helps maximize control, strength and balance plus, dampens vibration and reduces the effects of kickback and body fatigue while increasing overall digging comfort, productivity and jobsite safety. The 242H is also equipped with the convenient Auger-LOK™ for removing stuck augers. For use with the 2350 Series earth augers and auger extension.
Technical Specifications
Engine: 1.3 HP (1000 W) Honda GX35, all-position, 4 stroke
Starter: Hand rewind
Fuel: Gasoline, unleaded, automotive grade
Transmission: Totally enclosed, spur gear, grease lubricated
Maximum Digging Torque: 51 ft lbs (64 N.m)
Nominal Auger Rotation Speed: 166 RPM, no load
Auger Drive Connection: 1 inch (25.4 mm) round
Available Auger Diameter Range: 2 inch (51 mm) to 8 inch (203 mm)
Standard Auger Digging Length: 30 inch (762 mm)
Available Auger Extension: 15 inch (381 mm), plain-tube type
Weight (less auger): 28 lbs (13 kg)
Additional Information
Owner’s Manual
Catalog Page
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 17
Past 7 Days: 146
Past 30 Days: 715
All Time: 39,028
