Up to 20% off select tools
1 Diagram
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
MINIROOTER
Background and Identification
The Mini-Rooter model MR-CO is a drain cleaner made by General Pipe Cleaners. It includes 50 feet of 1/2-inch Flexicore cable or 75 feet of 3/8-inch Flexicore cable. It can clear most drain lines between 1-1/4-inches and 4-inches in diameter. The drain cleaner also comes with a Mini-Rooter Cutting Set (MRCS) that includes an arrowhead cutter, a 1-1/2-inch U cutter, a 2-inch side cutter blade, and a boring gimlet.
The Mini-Rooter model MR-CO includes a 0.33-horsepower motor. The motor features a momentary contact reverse switch for thermal overload protection. This feature prevents the operator from running the drain cleaner in reverse for more than a few seconds. The Mini-Rooter model MR-CO includes an air foot switch, a ground fault circuit interruption, and a safety slip clutch. The safety slip clutch reduces cable tangling and allows the V-belt to slip through the pulley system until excessive torque is reduced.
Mini-Rooter model MR-CO features an inner drum and distributor tube spring that is designed to prevent cable tangling. It also has a removable cage that allows for portability and switching cables. An optional power cable feed can drive and retrieve the cable.
The Mini-Rooter model MR-CO has an orange frame and a black motor cover. The cable-holding drum is silver in color. An optional dolly can snap onto the machine’s frame for portability. The machine weighs 60 pounds without the additional dolly.
Technical Specifications
Weight: 67 lbs. without cable.
Capacity: 75 ft. of 3/8 ″ or 1/2 ″ Flexicore Cable.
Motor:1/3 hp heavy duty, thermal overload protection, Forward / Off / Momentary Contact Reverse Switch.
Safety Slip Clutch: included
Flexicore Cable: Heavy gauge wire coiled tightly around 49 strand aircraft-type wire rope and heat treated.
Foot Pedal: Uses air pressure, so there's no electrical contact between pedal and motor.
Power Cord: 10 ft., 3 wire; equipped with ground fault circuit interrupter
Cutter Set: Arrowhead, 1 1/2 ″ U-Cutter, 2 ″ Side Cutters, and Boring Gimlet. Others are available.
Leather Gloves: With reinforced palm for hand protection.
Additional Information
General Mini-Rooter for 1-1/4 to 4-inch Lines Operating Instructions (EN, FR, ES)
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 11
Past 7 Days: 77
Past 30 Days: 312
All Time: 7,535
