Up to 20% off select tools
No Image
This wiki is missing a device image. Help improve this page by uploading one!
5 Diagrams
Documents
Models
GP7500E
Background
The Generac GP7500E is a portable generator capable of providing backup power during power outages and other circumstances that require portable electricity. It was introduced in 2015 by Generac Power Systems, an American company specializing in power generation equipment.
The GP7500E is equipped with a 357 cc engine and runs on gasoline. It can generate a running wattage of 7500 watts and a starting wattage of 9375 watts. This generator operates at 120/240V AC and features four outlets for various power needs. Measuring at 48 x 26 x 29 inches, the generator weighs 191 lbs when empty and operates at a noise level of 57 dBA at 25% load. The GP7500E employs a true power technology inverter, which ensures the provision of stable and clean electricity, which is essential for sensitive electronics and appliances. The generator's structure is composed of an aluminum enclosure with a corrosion-resistant polyester powder coat finish. Its features include a sensor for low oil shut-off, a digital data center, fold-down handles, and a wheel kit for portability. The generator operates for up to 14 hours at 25% load on a full tank, thanks to its 8-gallon fuel tank. It is compliant with CARB for sale across all states.
Technical Specifications
  • Model Number: GP7500E
  • Product Type: Generator
  • Engine: 357 cc OHV engine
  • Fuel Type: Gasoline
  • Running Power: 7500 watts
  • Starting Power: 9375 watts
  • Voltage: 120/240V AC
  • Outlets: (2) 120V 20A outlets, (1) 120V 30A outlet, (1) 120/240V 30A outlet
  • Dimensions: 48 x 26 x 29 inches
  • Weight: 191 lbs
  • Noise Level: 57 dBA at 25% load
  • Enclosure Material: Aluminum with corrosion-resistant polyester powder coat finish
  • Tank Capacity: 8 gallons
  • Run Time: Up to 14 hours at 25% load on a full tank
Warranty
The Generac GP7500E generator is equipped with a 5-year limited warranty. This warranty covers defects in materials and workmanship when the product is used for private, residential purposes. It is important to note that the warranty period commences from the date of purchase by the first retail customer. Meanwhile, in cases of commercial and rental uses, a separate 2-year consumer warranty applies. To claim the warranty, users should typically contact the manufacturer or the retail outlet where the generator was purchased, providing details such as the date of purchase, description of the issue, and the model number of the generator.
Generac 30 and 50 Amp Manual Transfer Switch Kits for Portable Generators
Generac GenTran Series Power Inlet Boxes for Portable Generators
Generac GP7500E 7500 W Portable Generators Specifications
Generac Portable Generators Catalog
Generac GenTran Series 30 and 50 Amp Portable Generator Power Cords
GenTran Series 30 AMP and 50 AMP KITS For Portable Generators Manual Transfer Switch Kits
Generac GenTran Series Manual Transfer Switches for Portable Generators
Generac GP7500E 49-State/CSA Electric-Start Portable Generator Specifications
Generac GenTran Series Plugs and Connectors for Portable Generators
Generac Portable Generator Maintenance Kits Bulletin
Generac GP Series Portable Generator Owner's Manual
Generac GP Series Portable Generators Product Brochure
Generac Portable Generator Maintenance Kits Product Information
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 52
All Time: 760
